STEERING WHEEL
First thing..
disconnect the hood release knob
Then remove the steering wheel column covers
Remove the lower plastic undertray . Disconnect the bulb for the lighting under the undertray (no pictures here, sorry)
Remove the screws for the switchpanel cover
Two at the base, one on the side hidden by the door when closed and two others hidden near the top of the steering wheel column(shown in the picture)
Take a bit of time to separate the switchpanel cover as its easy to break things that are still connected.
Like the interior light dimmer switch, the power window switch, the AAS controller, etc.
All these have to be disconnected.
Looking good at this point eh?
There is a metal underframe piece under the steering wheel column that holds one of the speakers.
Remove the four 10mm bolts and remove the tray.(90+ specific item)
There will be two air ducts that go under the steering column. One will be attatched with a screw and will hold the radio antenna cable.
Remove both ducts.
The steering column is held in place by four 12mm bolts.
Remove those bolts.
Support the steering wheel column so that it doesnt fall on its own.
To the bottom left of the steering wheel column near the fusebox there will be some connections that need to be disconnected.
Green
White
Blue
Now youll be in the home stretch to removing the dash. Just a few bolts here and there to be removed.
Remove the three 10mm bolts on both sides of the dash
Remove the 2 bolts on both sides of the base of the center console
At the center of the dash near the windshield there is a s
mall panel that houses the last bolt that needs removing.
(sorry. Overactive flash)
At this point you should be ready to remove the dash. The dash has pivot points at the base of the center console. Grab the dash firmly, lift up (as youll have to clear the steering wheel column mounting base that the dash rests on) and pivot the whole thing forward and out into your lap.
Unless of course you forget one last plug like this one for the
A/C unit.
(which I seem to forget about 50% of the times).
Which reminds me. At the moment of pulling the dash made an effort to make sure that there are no wires still connected.
Remove the dash out the passenger door
(easier than trying to go around the steering wheel column) and there you go.
Installation of new(ish) dash will be in the reverse order.
And there you have it. Dash removal made, er…. somewhat easy.
Comments, questions, let me have it. [ Here:
Comment on: Dash Removal - Mazda MX6 Forums: MX6 Forum (Comment on: Dash Removal) ]
Gavin
