Go Back   Mazda MX6 Forums: MX6 Forum > 1G MX6 (88-92) > 1G MX6 General > 1st Gen Projects/FAQ's > Project's and FAQ's > 1G FAQ: Appearance / Body
Closed Thread
Old 11-15-05, 15:39   #1 (permalink)
  Total: 391 Power: 5
Installing Steering Wheel
Remove the button
There are 3 screws on the back, one at each corner. unscew them.
the front can then pop off
then you will need a 19 socket
Carefull when pulling the front off with the horn wire
Remove the 2 screws also seen on top
the wheel is now ready to come off. wiggle it out, it might be a bit hard
the back piece them comes off
you are then left with this
05 STI
92 Galant VR-4
90 Eclipse GSX HKS' Former Promo Car
89 MX6 GT 4WS SOLD 89 PGT R.I.P
93 PGT5
/93 PGT5-SOLD/89 PGT-R.I.P. /96 PGT5 R.I.P.
KiNg MaRtY is offline
Old 11-15-05, 15:50   #2 (permalink)
  Total: 391 Power: 5
Now the steering wheel adapter kit from Grant. It can be picked up at any Kragen/Shuck's or Pepboys for $19.99
Inside goodies
First this goes on and make sure the nipples (reffer to the last pic in last post) align from the back to this part
This is a APC part that you will need if you are installing a wheel with 5 spots (if you are using the basic Grant 3hole wheel you can just adapt the wheel without this)
Bolt it up with the screws that came in the grant kit
Now you just bolt up the steering wheel and your done!
If you have a horn button than you just hook it up to the wire that came in the grant kit. you can see it in the last pic in there. I will installing my horn button shortly
05 STI
92 Galant VR-4
93 PGT5
Old 11-15-05, 16:02   #3 (permalink)
The Mod With the Mostest.
  Total: 1081 Power: 5
Panther37's Avatar
Comments can be found here: http://www.mx6.com/forums/showthread.php?t=145326 (Comments On: Installing Steering Wheel)
Panther37 is offline
Closed Thread
