#1 (permalink) | |
Non OE intercooler piping part numbers
These numbers are for the bypass to intercooler hose and for the intercooler to charge pipe hose (metal pipe to throttle body)
Important note: There are 4 different intercoolers for the MX6 and Probe GT. I have found the following intercoolers: Inlet and outlet parallel and a 90º angle with the intercooler _i Inlet and outlet angled and parallel with each other _/ And inlet and outlet offset from each other both stright and angled. My intercooler has both inlets straight at a 90º angle but offset from each other about a 1/2". The lower intercooler outlet is closer to the drivers side than the top. Anyways, if you have the same intercooler that i do, these part numbers will work for you should you need either the bypass to intercooler hose or the intercooler to charge pipe hose: Kragen/Parts America: C70592 Bypass to intercooler $10.99 - http://www.partsamerica.com/ProductD...tnumber=C70592 Intercooler to charge pipe E70759 $15.99 Last edited by SixSick6 : 8-22-05 at 20:44. |
#2 (permalink) | |
Here are pictures:
![]() Obviously a little cut to fit. But this one is the bypass to intercooler. ![]() Two Kragen hoses on the left and two stock hoses on the right ^ If you're wondering, all hoses are covered with several layers of high temp radiator hose tape. It works as a cast so to say and is a version of a poor mans hardpipe. |
#3 (permalink) |
Thanks for posting this. I was almost ready to go to Mazda for both of those hoses. They're like 65 bucks each!!!!
91Mx6GT,MTX, Kia fuel filter, Conefilter, NGK plugs/wires,Autometer Boost Gauge, PRD mbc @11psi.
Dyno: http://img75.imageshack.us/img75/6387/mx6gtdyno9bx.jpg Dyno2 12psi/3"dp and exhuast: http://www.njsr.org/pics/albums/user...yno%20copy.jpg |
#5 (permalink) |
No listing for the turbo to bypass-pipe hose? And Damian, exactly what brand/type of tape did you use and where did you get it? I went looking for some before my last track day and couldn't find anything exactly like it; closest I came was some "hose repair tape" at kragen that was basically black duct tape.
Apparently, I'm Mazda fo' lyfe...
1989 MX6 GT -::- 1991 RX7 Convertible |
#6 (permalink) |
I got 36 rubbers at Wal-Mart the other day for $3.50!!!!
![]() -Tyler |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#7 (permalink) | |
*Important note* Make sure that you don't wrap all the way to the ends. You'll never get the hose to stretch over the piping if you do ![]() |
#9 (permalink) | |
http://www.partsamerica.com/ProductD...tnumber=C70592 http://www.partsamerica.com/ProductD...tnumber=E70759 n00b. |
