Go Back   MX6.com > 1G MX6 (88-92) > 1G MX6 General > 1st Gen Projects/FAQ's > Project's and FAQ's > 1G FAQ: Submission Area
Old 5-22-05, 8:24   #1 (permalink)
  Total: 273 Power: 4
vrouv06's Avatar
How to do a catback side exhaust
So I decided it would be fun to make my exhaust come out the side today. And after a few hours of hard work (4-5 hours) I did it and it looks AWSOME!
Heres how to do it.
Tools needed
14,15 and 16mm socket wrench
Grinding and cutting wheel
Electric welder
Form of lift. (if your gonna use jacks use jackstands, my friend almost killed himself by not using them)
Can of WD-40
Glasspack (a motorcyle muffler like thing)
Step 1: First off lift the car up somehow and get it secure.
Step 2: Go to the back of the car and undo four hangers that are hooked up to the muffler. They have mushroomheads hooked up to the rubber mounts. I used some modified vice grips to push the heads out. Then there is one more to get in front of the rear right tire holding on to the exhaust pipe (cut that one off between the pipe and the rubber mount so you still have that bar on the mount)
http://community.webshots.com/photo...350192496RSdFwV
Step 3: Once all those hangers are off go to the middle of the car where there after the cat converter there is a section of exhaust where it is bolted together and undo those bolts (it's a pain if it's rusted over. In that case the bolts may break off, just replace them with new ones)
http://community.webshots.com/photo...350189553KrdHml
http://community.webshots.com/photo...350192878elpjod
Step 4: Now cut the exhaust pipe at the area here the pipe goes over the rear suspention bar. This will make it easier to get the whole thing out. So now your pipe should look like this
http://community.webshots.com/photo...350191893jIbsgZ
Step 5: Now you have to cut the pipe in these couple of areas
http://community.webshots.com/photo...350200417NefoIS
Step 6: Once youve done that weld the Glasspack to the pipe so it holds like so
http://community.webshots.com/photo...350192946ubvDlx
Step 7: Now you gotta make two kinda a tricky cuts at an angle right here
http://community.webshots.com/photo...350200870tttYgg
Step 8: Once you've cut that you gotta reweld it so it looks like this. This has now created the perfect angle for the tube to stick out on the side
http://community.webshots.com/photo/350187728/350192604APZVRw
Step 9: If needed take a file and just clean up your piece and the wholes.
http://community.webshots.com/photo...350191370KKqSnh
Step 10: Now to prevent any rust from taking place take a high heat primer and paint the entire thing. Make sure you completly cover all your welds nicly or they WILL rust out
http://community.webshots.com/photo...350193003sGZcKd
Step 11: Put the bolts back on and hook it back up to the exhaust.
http://community.webshots.com/photo...350191399IxfUlT
Step 12: Now you still have that unused hanger that was attached to the old pipe. Take the and hold your exhaust up as high as you can and pull the down the hanger and weld it onto the glasspack. (You may need two people for this) You want it to hold the thing up as high as you can cause it is pretty low to the ground but it shouldn't be too low.
Step 13: Take your primer and prime that hanger weld up so again it doesn't rust.
http://community.webshots.com/photo...350191838MNGXfA
Step 14: Put on your desired muffler tip and YOUR DONE!!!!
http://community.webshots.com/photo/350187728/350191446DDutjv
http://community.webshots.com/photo...350192462DcGjhB
http://community.webshots.com/photo...350191856qWVutj
There ya have it a new side exit exhaust. Im gonna get mine chromed at the local chromer and it'll look much better but i love it. This should also increase HP by a because the exhaust no longer has to go through all those turns.
Feel free to give a little bit of Karma
vrouv06 is offline   Reply With Quote
Old 9-16-06, 13:52   #2 (permalink)
  Total: 328 Power: 5
Jake's Avatar
How does this sound? And are you using stock cat?
4WS.ORG (4 wheel steering)
l
U-turn in the driveway!
Old 9-16-06, 14:24   #3 (permalink)
  Total: 328 Power: 5
Jake's Avatar
I want to also do a side exist exhaust. I already have a modded o2 housing.
I have a new hiflow cat, so Im gonna put that in. I figure I can replace the resonator with a small muffler or glass pack and come ou the side... should I use 2.5 or 3" pipe?
Where is best place to by mandrel U bends?
l
Old 9-16-06, 14:50   #4 (permalink)
  Total: 1051 Power: 5
Dyoel182's Avatar
Hmm, I really dont like the way that looks with the tip like that.
Old 9-17-06, 10:56   #5 (permalink)
  Total: 328 Power: 5
Jake's Avatar
Dyoel, did you have any feedback for me, tho?
"I figure I can replace the resonator with a small muffler or glass pack and come ou the side... should I use 2.5 or 3" pipe?
Where is best place to by mandrel U bends?"
l
