Go Back   MX6.com > 1G MX6 (88-92) > 1G MX6 General > 1st Gen Projects/FAQ's > Project's and FAQ's > 1G FAQ: Transmission
Old 4-22-02, 22:43   #1 (permalink)
  Total: 39 Power: 5
Is there a difference between turbo and non-turbo transmissions?
Yes, turbo and non turbo trannys do differ.
the turbo tranny is alot stronger than the non-turbo to handle the torque/hp the turbo engine puts out.
The non-turbo tranny is basically made of glass. if you try to put one on the Turbo engine, you will destroy the transmission in less than a month, probly even quicker than that. it was not made to handle any real power.
"Can i bolt the turbo transmission up to my non turbo engine?"
No.
The reason is that the non-turbo tranny will not bolt up to the gt motor. Differences in the number of splines, and how the bolt holes match up make it impossible.
"What about this FE3 i keep hearing about, will this work with my transmission?"
The FE3 motor will bolt up to the turbo transmission, and the tranny can handle the power of the FE3 engine.
But, if you try to bolt the FE3 up to the non-turbo transmission, you will more than likely kill the transmission very soon.
-meaty
...I need... more cars...
deadmeat is offline   Reply With Quote
Old 5-20-04, 6:31   #2 (permalink)
  Total: 111 Power: 5
No.
-meaty
this makes no sense?
the 2.2i-turbo transmission doesn't bolt up to the non-turbo 2.2i.
the 2.2i-turbo transmission does bolt up the the fe3-dohc
and the non-turbo 2.2i bolt up the fe3-dohc?!?!?
how can the non-turbo 2.2i bolt up to the fe3-doch if it got another boltpattern/splines
Mazda 626 FE-doch -88
Mitsu TD054-16G turbo, 1000cc injectors, 255lph WALBRO fuelpump, modified fuelrail, about 8.6:1 pistons.. EVO IC. Megasquirt controlling the fuel
Mitsubishi Lancer EVOLUTION 4x4 -93
YouAsk is offline   Reply With Quote
Old 5-20-04, 6:43   #3 (permalink)
  Total: 35 Power: 5
You need the right clutch and flywheel that goes to the matching gearcase to use any of them. The bolt pattern is the same.
If I am wrong someone correct me, but I am pretty sure I am right.
Tommy ~ 88MX6GT ~ HybridMX6 ~ BoostedMazda (I have too many names)
1998 Ford F150 4x4 Supercab Longbed - Stock and stayin that way.
88MX6GT is offline   Reply With Quote
Old 5-21-04, 8:36   #4 (permalink)
  Total: 42 Power: 5
You know deadmeat posted that back April 2002
I think you right Tommy
Bryan~88' Auto Alliance Probe GT
FLAPOC-Pres is offline   Reply With Quote
Old 10-28-06, 23:58   #5 (permalink)
  Total: 19 Power: 4
the turbo trans can too bolt to the n/a just need to change out to turbo parts lik mount, shifter links... etc.
rscircuitcity is offline   Reply With Quote
