Go Back   MX6.com > 1G MX6 (88-92) > 1G MX6 General > 1G MX6 Appearance Mods
Old 2-21-05, 0:45   #16 (permalink)
  Total: 64 Power: 5
hey I got a question, I was looking at the big rims posts, about which ones fit and which ones dont.. and I saw R33 Skyline (GTST/GTR only, GTS is 4 stud) and
R34 Skyline, does this mean the R32 wheels 16x6.5 dont fit ?They are 16 X 6.5 with a +40 offset. They have a lug pattern (PCD) of 5 / 114.3.
ENGINE
3" cat-back exhaust, APEXi N1 muffler, filled mounts, Walbro255lph pump,sabb93 fmic, 2.25" IC press bent piping,turboxs Type-H RFL bov ,turboxs boostcontroller 16psi stock turbo,magnacore 10mm wires, ngkV-power plugs, over bored .020 over, ported & polished head, double valve springs, SS valves, 5 angle head job, ZombieSS chip
EXTERIOR
R32GTR Frontend conversionR32GTR SideSkirts, R32GTR Wing ,Rx7FD Rims, Tokicoblue struts, Eibach springs
itscard0man is offline   Reply With Quote
Old 3-9-05, 16:48   #17 (permalink)
  Total: 113 Power: 5
All 5 stud skyline wheels fit
"Lack of pu ssy makes you brave man!!"
"Cocaine is a hell of a drug!!"
"What the fu*k is GOONY GU GU??"
"Mm mm mmm, that IS a tasty burger !! "
Boosting6 is offline   Reply With Quote
Old 3-16-05, 9:55   #18 (permalink)
  Total: 10 Power: 4
Ok I'm getting more confused reading this, would these rubs or no?
17X7.5 5X114.3 bolt pattern
Tires 205/40/R17
I think they wouldn't rub right?
quiksilver_182 is offline   Reply With Quote
Old 4-7-05, 2:49   #19 (permalink)
  Total: 21 Power: 0
I have 17x8 with 205/40/17 tires and i have no problems with them
Dumped626 is offline   Reply With Quote
Old 4-7-05, 11:14   #20 (permalink)
  Total: 473 Power: 4
retsamaksrepus's Avatar
It also depends on if the car is lowered....
Originally Posted by Mazda4ever
Originally Posted by zlyricist
i am also guilty of playing with my wankel instead of my 6.
retsamaksrepus is offline   Reply With Quote
Old 7-22-05, 19:05   #21 (permalink)
  Total: 10 Power: 4
hey guys, I need some help finding some nice rims that are light for my mx6. I'm still running factory and its a b!tch trying to clean in those stupid little gaps. Any ideas are welcome!
~*91MX6*~ is offline   Reply With Quote
Old 1-6-06, 21:17   #22 (permalink)
  Total: 217 Power: 3
Sorry wrong post (Panther please delete this)
mmmm beer MY LX 626 is NOLONGER
Now i own a 99 HONDA CIVIC EX and I love it
Originally Posted by D'sMx-6
Maybe you can get another six because apparently God doesn't want you in a Honda.
626mazdaracer is offline   Reply With Quote
Old 1-4-07, 12:09   #23 (permalink)
  Total: 887 Power: 5
zlyricist's Avatar
hi my name is zlyricist and i'm a rim noob
so if one was to buy a 17" or 18" rim, would it still fit if it was up to 7.5 or 8"?? my car is dropped 2 inches
and what's the smallest tire you can put on a 8" rim, or does that not matter?? 225s rubbed on my car, and 215's arent the most common size........hopefully im not way off here
any help much appreciated!
91 GT hy35 build in the works
06 maxima - the daily
Old 1-26-07, 4:26   #24 (permalink)
  Total: 2565 Power: 5
I'm thinking of picking up some IS300 rims. Not sure of the dimensions though. "I have a extra set of IS300 wheels and tires i no longer need. They have curb rashes. They are just sitting come pick them up. tires are 30% tread life. I will take any offer. 17"x7" offset +50."
Originally Posted by r32mx6
Old 1-27-07, 5:59   #25 (permalink)
  Total: 84 Power: 3
On a 7.5" wide rim, 205 is the smallest I'ld go.. It will look hillariously thin (width wise) unless matched to a taller tire (40-45). And mr. Dumped626, who is banned, is stupid. 205 on an 8" is compleatly retarded. granted 205/40 is not a dangerous stretch, but they are called side walls for a reason. if the side is tucked behind the lip of the rim, you risk chances of bending your rim on bumps, cracking the sidewalls, or even breaking the bead on the tire..
tisk..tisk..tisk.
I am running 215/35/18 because of our damn rear struts. I am dropped 2"/2.2", and have no problems with a 42 offset.
Later
-Scott-
I only Drink two days a week. Week Days, and Week ends
MesXco6rt is offline   Reply With Quote
Old 5-9-07, 0:43   #26 (permalink)
  Total: 10 Power: 2
i like aftermarket rims better than oem ive got 17'' motegi mr7's on my mx6 and i dont get any rub at all and its lowerd about 2 incheshttp://viewmorepics.myspace.com/inde...mageID=9878766
BoostedGt6 is offline   Reply With Quote
Old 7-7-08, 3:58   #27 (permalink)
  Total: 19 Power: 2
Ok so how do you figure out what kind of offset/backspacing you need when getting a wider rim? I've been reading tons about rims/tires, and I'm even more confused. I think I would like to go with a 15x8 215/50. Basically I'm going for the stretched tire look while getting a wider tire. If I can fit a 9" I would, but I'm having trouble finding a reasonably priced much less a 9" 15 at all. I saw gavin has 10.5's on the front so I'm assume it's possible, also would a 215 even be stretched on a 8" rim?
91Mx6GTChris is offline   Reply With Quote
Old 7-7-08, 20:58   #28 (permalink)
  Total: 33 Power: 1
Well, 215mm is about 8.5"...
1990 MX-6 LX - 'Julie'
1995 Escort GT - 'Max' - yup its got a ZE... BPZE, that is
chrmar is offline   Reply With Quote
