#31 (permalink) |
Style: ADR VENOMOUS
Bolt Pattern: 5x100 or 5x114.3 Size: 17"x7" Offset: +48mm sorry i have a 2nd gen mx6 but i did a search and this is what i was looking for except for a 2nd gen. these are rims that i am about to purchase.. they say that they will fit an mx6 93-97. but will they?? Last edited by Tessa : 5-18-07 at 11:48. Reason: 2nd gen opps |
Tessa SUPER GRAPE BLITZ/SHOGUN KIT
http://www.cardomain.com/ride/2143228 |
#32 (permalink) |
I just got 2nd gen swirlies 16x7 w/ 40mm on 205/55-16 and I had a rub on the drivers side rear, pretty severe rub, tire heated up and was audible plus tire smoke. Pass side rear is tight but no rub? I ran to Advanced 7 minutes before they closed all they had was wheel washers so I'm currently bandaiding it with them. Hoping to find somewhere with spacers tomorrow or else the stock rims are gonna have to go back on.
Hi my name is Tobin... and I'm a Mazdaholic
88 MX6 GT, 15 psi /90 626 LX/ 90 Probe GT, 16psi /95 Pathfinder, 4x4 5-speed//94 Mark VIII 4.6 4V Get your parts from allmazda |
#36 (permalink) |
Youre asking if your OEM 14in tires will fit the 17in wheels?
Hahaha, no not at all! 175/65/14's arent even low pro tires. You need to buy all 4 new tires for a 17in rim. The offset is good for the Mx-6. Id suggest some 215/40/17's for tires. I had them on my Mx-6 with the same rim size and offset. Sits perfect. |
Anyone want a NICE 1G? :-/
#37 (permalink) |
interesting picture:
![]() also here http://www.mx6.com/forums/general-au...ml#post1845569 (How to understand tires) |
#38 (permalink) |
i am running the stock Mazda 3 17. they are a 17x7 with a 52mm offset and im running a 205-45-17 and everything clears and no rubbing at all on my 91 626
http://www.cardomain.com/ride/2146610 http://www.dfwmazdas.com |
#40 (permalink) |
hey guys idk if i should post this here but i might be picking up a set of rims from a 1997 eclipse and i wanted to know if anyone knows if they fit(offset... i know bolt pattern will), weight, and if 205/55R16 will go without rubbing on a lowered car? i do notice VERY SLIGHT touching when i do a u-turn at any kind of speed (3mph+) with stock 185/70R14s
If you want something you have never had, you have to do things you have never done - Paul Pollard
