paint 3 cars in 2 days
I decided on friday to paing 3 cars in 2 days,
my 90pgt,91pgt and 88mx6gt. mission accomplished. probegt painted 2008mazda 6 redfire red prep,sanding ,taping and spraying ![]() ![]() ![]() mx6gt, stock metalic grey ![]() ![]() ![]() Last edited by ademan : 9-16-07 at 21:30. |
#2 (permalink) |
#4 (permalink) |
#6 (permalink) |
Yup they all look good mines is prime and thinking about painting it smokey grey
91' Lx to 89' GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/15psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
#8 (permalink) | ||
make sure is not windy when you paint and also wet the ground with water so the wind wont blow crap on it. using a fast reducer allowed the paint to dry fast (2 min-5min btw coat). usually body shop use a medium reducer which take longer to dry. the car was painted outside with no single run or orange peel. Quote:
let see. 3 quart of red base paint $140 red paint always cost more 3 quart of grey metallic $90 2 gallon reducer $50 1 quart activator $25 1 gallon of clear $40 sand paper, 150,220,500,1200 grit $10...harbor freight masking paper and tape $20 Total....$375 Last edited by ademan : 9-17-07 at 19:56. |
#10 (permalink) |
laquer thinner is used for primer not paint, as for the gun i used hvlp top feed gravity gun, even though i preffered the other. but you can use any gun you desire
#11 (permalink) |
3 quart of grey metallic $90 2 gallon reducer $50 1 quart activator $25 1 gallon of clear $40 sand paper, 150,220,500,1200 grit $10...harbor freight masking paper and tape $20 Total....$375[/quote] not paying someone 2grand to do it for you.....priceless |
MX6 2NRIt may say Veteran now, but im still a noob at heart |
#14 (permalink) |
#15 (permalink) |
While you get an "A" for effort, I am very skeptical as to what these cars look like up close. Painting outside or in anywhere that is not a clean environment is generally not a good idea as you end up with lots of dust flecks in the paint. It is not hard to tell a good factory paint job from a DIY job. The pic of the grey car kind of makes it look like it has a dull finish.
