Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > General Automotive > Engine Management > 1G MX6 Engine Electronics and Management
Old 7-12-08, 22:20   #16 (permalink)
  Total: 163 Power: 5
megalomaniac32x's Avatar
u use the disty for a crank trigger but use seprate coils for ignition?
91 626 DX, 89 F2T swapped, probinator chipped ecu, 2.5 inch exhaust and downpipe, zebel housing, 12 psi, mazdaspeed FSTB, blaster2 coil, pacesetter sts, rstb and lower tie bar, suby calipers, rear disc brakes, PGT rear swaybar, eibach springs, MSD 6A, ic hardpipes, DSM recric valve, AWR mounts
Old 7-12-08, 23:16   #17 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
you can if you want
Old 9-24-08, 15:35   #18 (permalink)
  Total: 1075 Power: 5
zlyricist's Avatar
with this setup, are all disty signal outputs still necessary for the MS?
signals being NE1, G1 and G2?
1991 MX6 GT - my slut
95 LS SOLD - 96 M edition SOLD - 93 KLZE new daily
Old 9-24-08, 20:21   #19 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
if going wasted spark (or single coil) all you need is the modded ne wheel. if your doing cop with the gt dizzy, you use them all. alternatively you can use them all and still go single coil or wasted spark if you really don't feel like grinding teeth.
Old 9-25-08, 9:38   #20 (permalink)
  Total: 150 Power: 4
You could also go coil-on-plug with just the NE wheel, if you only filed off one tooth instead of two.
Matt Cramer
DIYAutoTune.com - Megasquirt, fuel injectors, wideband O2 sensors, and more
Matt Cramer is offline   Reply With Quote
Old 9-26-08, 16:53   #21 (permalink)
  Total: 1292 Power: 5
fredio54's Avatar
COP (like that, or any which way with ms2) = slow starting though. Just something to be wary of.
Crank pickups are WAYYYY (ok, thats a gross exaggeration) better than cam driven ones.
Missing tooth crank wheel is the best solution with MS IMO.
Fred.
Old 10-6-08, 14:07   #22 (permalink)
zlyricist's Avatar
just to make sure im doing this right....
if i wired so that the ne+ signal goes to pin 24, then ground the signal on the MS as well (some diagrams show pin2, others pin7?) i would need to jumper the VROUTINV to the TSEL?
Old 10-6-08, 16:51   #23 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
ne+ to pin 24, ne- to pin 2.
also yes, vroutinv to tel is how i did mine too.
dont forget this too
http://i3.photobucket.com/albums/y82...1/DSC00576.jpg
Old 10-6-08, 17:01   #24 (permalink)
zlyricist's Avatar
the tachselect jumper, or your fancy map sensor?
Old 10-6-08, 17:06   #25 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
actually that's not my megasquirt, just one i built for someone else
Old 10-2-09, 12:56   #26 (permalink)
Shove it!
  Total: 1884 Power: 5
Zach's Avatar
bump for always good info...especially when you're modified disty blows up like mine did
postin tryna get you booted
Parting out Gray 89 GT
Originally Posted by Kansas
