Go Back   Mazda MX6 Forums: MX6 Forum > Open Forums > General Automotive > Engine Management > 1G MX6 Engine Electronics and Management
Old 4-22-08, 16:13   #1 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
pictures of modified gt dizzy for 12-1 in megasquirt
i get asked about what tooth to grind a lot so im posting pics.
that one, 3 right of that g wheel, then the one 180 opposite of it.
just make sure they are flat and you don't screw up the teeth beside them (note: one of mine is slightly pointed now)
if it helped.
Old 4-22-08, 16:16   #2 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
edit: reserved space for changes?
Old 4-22-08, 16:52   #3 (permalink)
  Total: 1292 Power: 5
fredio54's Avatar
is it just me or did you destroy the tooth on the right of the gap in the last picture there?
Old 4-22-08, 17:16   #4 (permalink)
Shove it!
  Total: 1884 Power: 5
Zach's Avatar
yeah...he speared it pretty good
So you grind two teeth off? That one, and the one directly opposite?
postin tryna get you booted
Parting out Gray 89 GT
Originally Posted by Kansas
Old 4-22-08, 17:30   #5 (permalink)
  Total: 217 Power: 5
Isnt that a 24-2 wheel now?
Since you cut 2 tooths off and they are 180degrees apart and when counting in your pictures there is 11 on each side which makes it 11+11+2 = 24.
-:|my GC|:-
Mazda 626 lx coupe 1984, 2l FE carb., 99% rustfree, Waiting on shelf: Custom Koni's + Koni springs
-:|my GD|:-
Mazda 626 glx hatchback 1990, FE-DOHC, Dutch FSTbar, MS2 PCB v3.0, Innovate LC-1, Mitsubishi TD04-15T @ 0.55bar. Soon TD05H-16G + new manifold
eraezer is offline   Reply With Quote
Old 4-22-08, 17:35   #6 (permalink)
  Total: 70 Power: 3
sweet. thanks for the pics...one less thing I have to worry about
GT3782VA VGT, FMIC, custom 2.5" hardpipes, ching chong BOV and 38mm wastegate, 2.5" exhaust...MS2Extra, Boost, oil pressure and EGT autometer guages. LC1 Wideband
http://www.mx6.com/forums/1g-mx6-for...ml#post2168882
SiFlyBy is offline   Reply With Quote
Old 4-22-08, 18:23   #7 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
...kinda i took off the front of it on accident, so now it has more of a wedge shape. works fine though
yeah
megasquirt uses it as a crank signal. for each crank movement it moves half a turn. therefor its a 12-1 crank wheel basically. technically it is a 24-2 cam sensor.
Old 4-23-08, 3:14   #8 (permalink)
fredio54's Avatar
ROFL, better you than me! Have you scoped it? I'd be interested to see how it looks. There's a reason it works, but i bet that pulse is off centred compared to the other giving you (if you used a decoder that cared, ie ms2) rpm wobble. My scope of my 36-1 is wonky as because it's not straight on the pulley... however the tooth spacing is right, so the centres are good. so long as it works i guess :-)
Old 7-10-08, 12:38   #9 (permalink)
  Total: 20 Power: 5
what is the diffrence between the gt dissy or a lx/gl when using mega squirt?
1989 MX-6 GT -RIP
1990 MX-6 in the works
whitestalker89 is offline   Reply With Quote
Old 7-10-08, 15:23   #10 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
lx one needs to be welded shut, gt needs to have 2 teeth removed. you end up with the same thing, just a different way of doing it.
Old 7-10-08, 17:54   #11 (permalink)
  Total: 431 Power: 5
So are people doing this rather than using two VR conditioners with the 24 tooth Ne signal and then the g1 signal which is a one tooth wheel in the gt disty?
This seems like a good option for people running v3 since it only has one conditioner. I bought a 2.2 with a daughter card that has two VR conditioners. Its built but i haven't added the daughter card yet... we'll see what happens.
My IHI turbo page
Old 7-10-08, 22:00   #12 (permalink)
  Total: 519 Power: 3
compnut21's Avatar
pretty much. i didnt feel like adding more electronics so i removed some teeth. imo it was easier to do than adding another vr to the v3 board or finding a welding a lx dizzy.
Old 7-11-08, 8:55   #13 (permalink)
  Total: 150 Power: 4
A lot.
GTs used a Nippondenso 24/1 distributor much like a Toyota ESA. These have computer controlled advance.
The GL used a 4 tooth wheel, a VR sensor, and a mechanical advance. Taking control of the spark means locking out the advance mechanism - or you can just run fuel only if you're not going to be tuning your spark curve.
And the LX V6 is a Ford TFI that can be used with no mods to the distributor and more or less the same Megasquirt setup as a 5.0 Mustang.
Matt Cramer is offline   Reply With Quote
Old 7-11-08, 12:23   #14 (permalink)
Shove it!
Zach's Avatar
Originally Posted by Matt Cramer View Post
A lot.
+7
Old 7-11-08, 17:49   #15 (permalink)
  Total: 431 Power: 5
they're technically 24-2 err 24-1-1.
There are three wheels, two of them have 1 tooth OR maybe there is two wheels, one with 24 the other with 1 tooth but there might be two pick ups. I'm not really sure how it is physically setup, but i do know that there are 24-2 signals per cam rotation.
Not to hijack - can some one PM me if they are running the gt disty with two VR sensors in MS? I need to clear up a few things...
My IHI turbo page
