Originally Posted by Zach
What trim T04E?
What is a 6 Boost manifold?
Don't you mean 550cc injectors? I'm assuming RX7's
044 Fuel Pump...Bosch, correct? I had a Walbro 190 serve me fine
Valve Springs, there is a whole thread on them. Basically GC 626 duals with seats and get the solid lifters machined to fit the rocker arm shaft of the F2
Are you going with Delta or Colt?
Bottom end is forged from factory...don't waste your money
I would suggest an Evo 8 Intercooler (I have one for sale with some piping)
3" is good...
power from 20psi is a relative term...it's all about your tune, but typically you can expect 275whp+
I would suggest a fidanza and DXD clutch as well.
60 Trim on the TO4E
6 Boost manifold are the best manifold available in Australia
550cc Walbro Injectors
Bosch 044 is correct
Unsure with Delta and Colt. As i cant get hold of ether of them. Just want a regrind thats going to pull better up top.
Motor had low compretion so i brought them for a fresh rebuild.
I will have alook at your FMIC
3" I thought would be good
Hoping to get a really good tune
Im getting a Excedy heavy duty twin plate clutch made for it.
Do you know anything about building the gear box or if i will need it built.
Im buying better axels and the LSD for our cars this week aswell.
Thanks Chris
