does anyone know another hole in the firewall for access to the engine bay.. the hole under the master cylinder is occupied with a cable for my battery because i moved it to the trunk for more space... i just need it to be big enough for the boost gauge and air/fuel gauge wires and hoses... any help is greatly appreciated.
I'm fond of the hole where the A/C drains. Just look underneath the glove comparment (there is a panel you have to remove), and there is a rubber tube which drains water out of the A/C condenser. That is easy to use, a little bit of rerouting is required, but anyway...
Or poke the wires through an existing rubber gromett with wiring in it already.
like maybe the throttle cable or something else... i think you
d rather the boost guage hose to be as short as possible and going towards the passenger side and back over to the driver isnt shorter heh
Mods: KLDZE 8.7:1, HotShot Headers, 3" hi-flo kat & Injen Catback, CAI, CM stg 3 clutch & AASCO FW, AWR mounts, KVR SS brake lines, Tein SSP EDFC Coilovers, F+R STB, M-Edition red tails, E-Specs, SS door sills, ZT2 WBo2, Traction bars, PAR 5spd, Haltech.
look directly behind the .. say.. where the ecu's mounted.. there's a plate.. and little rubber cover the unbolts.. and you can pull it out.. drill a hole and bolt it back up.. sometimes its just rubber.. so you could put a hole in it!!
