you can get more power by using the forged or cast pistons of a higher comp. at your current boost, and with that you wouldnt neccessarily need additional fuel mods. this being said, however, as you already have a boost controller and are planning on a rebuild, make sure all bearings, seals, ect. are replaced and turn up the boost. in doing so make sure you've got enough fuel going to the engine to keep it from burning a hole in your pistons as well as other nasty stuff. the higher boost will help out far more than the high comp pistons will. the stock cast should be good for quite a bit, but if you're thinking about tirepressure levels of boost, then definitely go with the forged, and get a good metal headgasket.
