best way to port o2 housing? - Mazda MX6 Forums: MX6 Forum
Old 4-28-06, 21:11   #1 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
im getting the VRS turboback exhaust system 3inch and until i can fab a better o2 elbow(making the flange on the mill and then custom making the whole pipe) im curious what a quick hackjob on porting the housing would be? anny suggestions? or is it fine as is?
Mazda4ever is offline   Reply With Quote
Old 4-28-06, 21:45   #2 (permalink)
  Total: 33 Power: 5
i am curious of this as well, can some porting be done on the stock dump pipe?, if so what tools to use and is it worth it?? thanks
2 1/2 inch custom exhaust to bomz racing muffler, zombie chip (16 psi.), walbro 190lph fuel pump, MBC, magnecore 8.5mm race wires, msd blaster ss coil, cone filter w/adapter, rebuilt turbo, tons of replacement parts, 15.1@92mph spinnin' like crazy!!
cmansturbomx6 is offline   Reply With Quote
Old 4-28-06, 23:04   #3 (permalink)
  Total: 42 Power: 5
i donno about how much you can port it, but this has been up on ebay for a day or so now, seems like it might be better than a port job, or a fabed up dump pipe. I dont know the size, but ide assume at least 2.5".
http://i15.ebayimg.com/03/i/06/e3/58/f2_1_b.JPG
'The box is there for a reason, I like thinking inside it. I feel safe in there.....'
-Tucker
RvB
My Car
Malkara is offline   Reply With Quote
Old 4-29-06, 2:23   #4 (permalink)
  Total: 203 Power: 5
probinator's Avatar
take a grinding wheel and go at it.
89 Ford Probe GT, It's not stock.....
chip info here.http://www.cardomain.com/ride/728690/1
ZE Eprom Chips, and First Gen GT chips for sale.
probinator is offline   Reply With Quote
Old 4-29-06, 3:37   #5 (permalink)
  Total: 348 Power: 5
Mazda4ever's Avatar
i seen that on ebay but its like what 300-400 bucks? sheit.. i can make something just as effective for 1/8th or less the price it just wont look as pretty
if you mean for like a hand grinder how the hell do you get into all those harder spots? i tried using a rotary file but it would take FOREVER literally
Old 4-29-06, 10:55   #6 (permalink)
  Total: 1118 Power: 5
zlyricist's Avatar
i would think you could use a dremel on it, i dont know if you can get and extension to get deeper into there because i dont have one.........i've been wondering the same thing though myself
i wanted to port my 02 housing, and i heard some bad things that it cracks real easy after porting and that it's not worth the extra work........but the damn thing is a bottle neck i'm sure porting it out would help lots if you can do it without compromising the integrity of the pos
1991 gt - still busted
1999 626 kl manual
2002 maxima
Old 9-20-06, 23:02   #7 (permalink)
  Total: 328 Power: 5
Jake's Avatar
hey, zlyr... did you ever try porting the o2 housing?
4WS.ORG (4 wheel steering)
l
U-turn in the driveway!
Old 9-21-06, 2:02   #8 (permalink)
  Total: 1001 Power: 5
I ported a manifold and 02 housing, took out the 5 dimples for the bolts and opened the housing considerably, ported the manifold from one end to the other.
Took almost 60 hours, used flap wheels and sand paper cartriges.
Get a set of ferris porting bits, summit racing sells them cheap.
Jake you seem to be on a quest to find a bigger o2 housing, you could port the turbo side of the housing some, then do as Larken had and cut the O2 housing before it tappers and weld a lager pipe to it (or have the welding done).
Nothing ever cracked, ran the Tbird inthat same housing.
Old 9-21-06, 8:29   #9 (permalink)
  Total: 328 Power: 5
Jake's Avatar
If you could, then you would have a LOT of friends, me included.
$300 is too crazy much for that ghetto chrome thing. Obviously, they are recouping the hours it took designing it... which, btw, I dont like. I dont like that the wategate tube dumps back in at such a 90 degreeish looking angle. And I HATE CHROME. What the hell! Its a frikking o2 housing. I bet the chrome turns blue/black after 30 seconds of running time.
So anyway... are you serious about making or attempting to make 1 or more?
l
Old 9-21-06, 8:35   #10 (permalink)
  Total: 328 Power: 5
Jake's Avatar
Howd you guess? Just cuz I posted in about 4 related threads, heh...
I already have one with a 2 1/2 pipe Outlaw330r made but he really didnt make it that well. No offense Outlaw but I got what I paid for, heh. Its piecut pipe and there are still weld sticks protruding into the passage, basically its a stock housing that he chopped right about at the taper. He shoulda chopped a little higher. It still forces the waste gate air into the same little area which Im beginning to think is not that big a deal. THe waste gate is not coming open anyway until 14+ PSI boost in my car when Im done with it.. but my biggest issue is the square restriction less than 2" wide. I want to open that up some but how much room is there to port? You said you removed the "dimples" how far out did you go?
l
Old 9-21-06, 11:18   #11 (permalink)
zlyricist's Avatar
i think someone just needs to buy the oversized o2 housing off ebay from that german company, and make copies of it
they only listed it once but it didnt sell, i'm sure they still have it
1999 626 kl manual
2002 maxima
Old 9-21-06, 12:08   #12 (permalink)
  Total: 328 Power: 5
Jake's Avatar
Except as I said before, I dont their design, because the wastegate tube appears to dump back in too early. I think we'd be better off redesigning one from scratch. Also, I want to make a downpipe to the Cat with a flex pipe.
I see little point in making a better O2 housing if yer gonna squeeze it back < 2" to go into the stock downpipe.
[JOKE] Maybe I should make one that has a little wastegate truck stack that sticks out the hood?[/JOKE]
I think "my" kit would be a better O2 Housing that clears the AC, comes with a downpipe AND a sexy flexy pipe all 3" or as 3" as I can make it. THEN you either buy a reducer to go to your stock cat (for wimps) or you just flange it off there and sell a matching flange and let the customer buy a VRS kit or their own mandrel bends.
l
Old 9-21-06, 13:08   #13 (permalink)
  Total: 1951 Power: 6
Zach's Avatar
someone should make a cookie cutter housing
88 626 4WS Turbo Noble White
97 626 LX V6 Timberline Mica
Email me for a turbo rebuild!
Old 9-21-06, 13:22   #14 (permalink)
  Total: 328 Power: 5
Jake's Avatar
Dangit, I cant find the picture of that $299 housing sold ob eBay... can someone help me
l
Old 9-21-06, 13:26   #15 (permalink)
Zach's Avatar
IIRC, it looked stock, except it had a seperate tube for the WG, and diameter was increased to 2.5"
