correct way to check atx tranny fluid level?? please read>> - Mazda MX6 Forums: MX6 Forum
Old 5-7-06, 21:40   #1 (permalink)
  Total: 33 Power: 5
ok i just did the tranny filter and fluid change and now i'm checking the fluid level, i always thought that the car had to be at operating temperature and in neutral to get an accurate reading, is this correct??
also my fluid level dipstick has what appears to be two different reading levels one side says something like 68 degrees and the other side says 149 degrees which one is the best one to use.
i just need to know what the procedure is for checking the fluid and getting an accurate reading.
remember its an automatic
thanks alot
2 1/2 inch custom exhaust to bomz racing muffler, zombie chip (16 psi.), walbro 190lph fuel pump, MBC, magnecore 8.5mm race wires, msd blaster ss coil, cone filter w/adapter, rebuilt turbo, tons of replacement parts, 15.1@92mph spinnin' like crazy!!
cmansturbomx6 is offline   Reply With Quote
Old 5-7-06, 22:30   #2 (permalink)
  Total: 551 Power: 5
Well, I don't know that it has to be in neutral. I would think you can leave it in park. I always thought the 2 marks meant "full" and "low". But, since they have temps beside them, I would assume that the "68" is for when the car is cold and that the "149" is when it is at normal operating temperature. So, as long as the fluid level is around the mark at the right temp, it should be okay. Just pull the gear out, wipe it off, stick it back in, pull out and read. Just like the oil. If the car is cold, you want the level to be with the mark for the 68 degree and if it is at "normal" operating temp, it should be with the "149" degree mark. Right?
'00 Yamaha R1
'92 Ninja
'95 Millenia
MazdaMan069 is offline   Reply With Quote
Old 5-7-06, 22:56   #3 (permalink)
  Total: 70 Power: 5
make sure the car is running and drop it in drive a few times and then check it with the car running while in park (or neutral) you do this to make sure you have oil in all the little spaces and the tourqe converter because if not you'll have a high reading.
My GT was brought back from the grave and im slowly putting it back.
My Love (Sara)- http://www.cardomain.com/ride/731732
heyitsmikey128 is offline   Reply With Quote
Old 5-8-06, 10:56   #4 (permalink)
  Total: 33 Power: 5
alright thanks guys, mazdaman the dipstick has the different readings on different sides of the dipstick, the 149 side has the full level clearly about 1 inch up further than the full mark on the cold side, i was just curious to see which one was the better way to read it. Thanks
