#1 (permalink) | |||
Ghettodyne Narrow Band A/F Ratio
As said previously on measuring voltage with narrowband O2 sensors:
http://www.mx6.com/forums/showpost.p...5&postcount=11 (Running Lean Need Advice) http://www.mx6.com/forums/showthread.php?t=153896 (A/F Question....) http://www.mx6.com/forums/showpost.p...&postcount=103 (Vaf Hack Thread?????) Granted it's nothing compared to an actual wideband sensor with module but should give you an idea much better than a standard Autometer 4375 type: ![]() Which is nothing more than a lightshow if you don't equate each light with a theoretical A/F reading. Most if not all narrowband sensor read as follows: 14.7:1- 0.50v 14.6:1- 0.60v 14.5:1- 0.70v 14.2:1- 0.80v 13.5:1- 0.85v 13.2:1- 0.90v 13.0:1- 0.92v 12.5:1- 0.94v 12.0:1- 0.95v It looks like this: ![]() ![]() In closed loop mode the ECU will monitor the O2 sensor and the voltage should be between 0.3v~0.7v. But under acceleration (open loop) the ECU will ignore the O2 sensor and switch to default maps at which point you should see voltage between 0.70v~0.96v. You can measure this with any digital multimeter: Then correlate the voltage readings to your fancy light show: ![]() ![]() ![]() ![]() ^ The above numbers and lights are not accurate with a narrowband and should not be considered accurate with anything but an actual wideband sensor. It's just for demonstration purposes. If you wanted to confirm accuracy you'd need a wideband and a narrowband to confirm which light correlates to which voltage. The lights on the above .gif are with an actual wideband sensor. Keep in mind that the transition between lean and rich with a narrowband O2 sensor is very steep and there can be quite a difference between on voltage reading while cruising and the same or close to the same voltage WOT. Quote:
Here is the Autometer pdf file for the fancy lightshow: http://static.summitracing.com/globa...s/atm-4375.pdf According to their info, the gauge lights one LED for every 50mV. This means that theoretically you should be looking for at least 3 green LEDS lit for 0.85v (somewhere in the 13.5-14.0 vicinity), 4 lit for 0.90v (13.0-13.5), and 5 lit for 0.95v putting you in the 12.5~13.0:1 vicinity. Again, this is not fact and not true in all circumstance. Quote:
Again, these numbers are a guesstimate and by no means factual or a subsitute for a wideband. Quote:
Here's a good pages giving more info: http://www.aa1car.com/library/o2sensor.htm http://www.aa1car.com/library/wraf.htm http://www.aa1car.com/library/2004/us10438.htm http://en.wikipedia.org/wiki/Oxygen_sensor http://en.wikipedia.org/wiki/Air-fuel_ratio_meter http://www.freewebs.com/air-fuel-met...n-sensors.html http://www.forparts.com/BoswidebandO2.htm Last edited by SixSick6 : 2-16-07 at 11:18. |
#3 (permalink) |
this might be a good thing to use for this ..
http://cgi.ebay.com/ebaymotors/STING...09340733QQrdZ1 can mount it and itll look good and show low voltage unlike analog meters... good infor sick.. one question about my a/f guage as it doesnt work it just lights all the lights or some [shizzle].. would a bad o2 sensor cause this?? ive tried several gauges./// what happends when ur runnig like a a/f of 11s? at .95-1v its only 12..can the o2 not read that rich ? also what about taking a wideband from a honda/volkswagen since some of them had them and then installing it and running just a gauge off that would that work...how would u wire it... thanks Last edited by turboed2.2 : 7-13-06 at 8:03. |
#4 (permalink) |
Yup you could use that too, BUT, the point is that they're not all that accurate.
The voltage itself is based on temperature which is different than how a wideband operates: http://en.wikipedia.org/wiki/Oxygen_sensor http://www.wmsracing.com/o2/tech.htm http://www.gmtcny.com/WBO2S.htm http://www.plxdevices.com/AppNotes/P...Technology.pdf Be sure to check out the MegaSquirt Manual for great info on Oxygen Sensors etc http://www.aa1car.com/library/wraf.htm Last edited by SixSick6 : 11-29-06 at 19:57. |
#5 (permalink) | |
You gotta do the cooking by the book, you know you can't be lazy |
#6 (permalink) |
Most wideband controllers have an option for simulated narrowband. That way you can get a true/accurate wideband reading from the O2 sensor and your ECU still gets the signal it expects from the narrowband sensor. This eliminates the need to multiple O2 bungs.
#8 (permalink) | |
#9 (permalink) |
#1 does. You hook it directly to the O2 wiring going to your ECU. The ECU is already preprogrammed from the factory to expect the signal from a narrowband sensor and will still work the same way regardless if there is a wideband sensor attached. Of course the sensor will be more accurate but it doesn't matter. It's only more accurate to the control unit, not the ECU. The ECU could care less and the signal is merely a simulated 0.5~1v signal.
#10 (permalink) |
I'm not asking about faking out the stock ecu with a fake signal. I just want to verify that you can hook up the autometer gauge to the lm1/lc1 and actually get a usable signal, not just a disco light show.
#11 (permalink) |
Yes Joel. But the bigger question is why you're questioning things things that you've already gotten the answer to in a different thread?
http://www.mx6.com/forums/showthread.php?t=156004 (autometer a/f gauge to: wideband??) Or maybe my hard drive is just bigger and stores more useless info? ![]() Look here too: http://www.mx6.com/forums/showpost.p...0&postcount=10 (Magik 8, question... [just bought an innovative motorsports xd-1 and lc-1...]) |
#13 (permalink) |
YESSSSSSSSS. Why is that so hard to understand?- two links. 6.5 is what you want to read.
#14 (permalink) |
No ever came out and said that, they just kept repeating that it hooked up and worked. I didnt care that it hooked up and worked because what would be the point if the signal was a narrowband imatation that wasnt accurate in the first place?
