#16 (permalink) | |||||
#17 (permalink) |
that makes more sence Six......I thought you wanted me to put that POS carb on there.....
And yes your right about switching from efi to carb....... Guys were doing that with mustangs untill they found out they were slower.... as far as a holley for me, umm, well, I have a 650, (2) 750's, and 850/750, a 1000 race demon..... I have alot too choose from if I went that route, which is doubtful.....for obvious reasons..... And carbed turbo's...yep, I remember my 81 LeSabre Sport Coupe with the 3.8 turbo. The carb was chewed, and the car was way to rich on an idle, but put it too the boards, and that old boat would fly!! |
Gettin blown by one 19yr old...NICE!! Gettin blown by two...PRICELESS!!
89 MX6 Turbo......waiting for the road again....someday....maybe!!! ![]() 89 626 Turbo Hatch....everyday driver! ![]() 89 ZX7 wishing it was turbo...... ![]() Wife's cars- 2001 Echo(driver) / 1991 GT Mustang(summer) |
#18 (permalink) | |
No, you could use parts that already exist. The carb could be whatever. The hard part would be tracking them down:
![]() I just found out Radinov has one: http://www.mx6.com/forums/1g-mx6-gen...-magazine.html (My car in a magazine) |
#19 (permalink) |
i really was just wondering if anyone had ever tries it just for the hell of it and saw wwhat happen.. cuase I was pretty sure liek you said.. you can turbo a carb mustang and get ridiculous power with out all the elctrical crap you gotta go through somtimes..
Rob..."Bobby Hays!"
#21 (permalink) | |
Six did you notice that Radinov and the magazine both refer to his engine as a 2.0l 12v ? is this a mistake or is it a shorter stroke block like the FE3 with a f2 head. Migh be a good platform to turbo charge. But it sounds like that engine in its curent state would be the worst of both worlds, the limited rpms and flow of the F2 head on a block that makes little torque, not to mention the carb. |
#22 (permalink) |
it is in fact a 2.0-12v SOHC
i had one in my totalled red coupe. this engine is seen the most here, the head is the same as a 2.2i-12v, cam is different, it has a mechanical fuelpump which is driven by the cam ( it has an extra lobe on it.) see some pics here : http://www.mx6.com/forums/1g-faq-eng...e-fe-dohc.html (1st Gen PROJECT: my engineswap: from carburated to twincam injected. (FE--->FE-dohc)) thanks ![]() |
#23 (permalink) | |
Yeah I saw that but figured it was just an error. Wouldn't be the first time a magazine has written something incorrectly on a car that they don't own. Ask the guys in Europe.
EDIT: Ahh there ya go. Frank was writing at the same time. What about the crank, rods, and the deck height of the block. How do they compare to the F2? |
#24 (permalink) | |
Karma owed to Dutch. 2.0l 12v, curious, does this have something to do with engine size taxing? but then why not use the 2.0l 16v. When you say different cam is the extra lobe for the FP the only difference between it and the F2? Is that lobe just before the distributor? If so all the 88-89 Mx6/626 Gt's and N/A's have the same lobe (here), none of the probe cams seem to have them, the 90+ mx6/626 dont either. Always wondered what damn engine that loab was for, I knew it was a mechanical fuel pump loab, but couldnt figure out what engine used it, the b2200 is an 8V head, the previous gen 626's were 8v... Unless of course they made a carbed, 12v 2.2l also? Did they offer the 2.0l 12v in 90-92 or did it disapear like the extra loab on the cam did here. I am assuming that it has the same bore as the 2.2l just a shorter stroke? It would make a cleaner powerband in turbo application, but crazy torque is the best feature of the F2T . Last edited by Mazda Carnage : 5-8-07 at 23:09. |
#26 (permalink) |
when will you bastards get it through your heads that the heads are not "mx6" or "2.2" they are just mazda 12v F heads. used on utes, cars 1.8,2.0,2.2 the works.
i was going to say >> new mani a must because dry != wet, but you are right, there are carbed 12v manis. still a sh|t manifold though, and who would want a carb anyway? easy? nah. harder than megasquirt if you ask me... but then again, i am a software developer during the day before i put on my overalls and work till obscene hours in the carport. btw, the b2200 comes in 12v too and injected sometimes. heads blocks. interchangable in the most part, and totally seperate. fred. |
#27 (permalink) |
Some info for you all
N00b to mx6.com, first post, but I gotta say something. My current project is turboing a carbed B2200 with a .48 T3, humongous Volvo intercooler, blowoff valve from a 1993 subaru WRX (blows off at around 19PSI) All "ghetto," but less money means more time and more time means more research.
1. Yes, you can turbo a carb setup. Saab, Volvo, BMW, Mercedes, Peugeot, Ferrari, Corvair, Buick, etc? They all had very notable performance cars in their day and they were all carbed. 2. At low power levels (sub-300HP), carbs are not a limiting factor alone. 3. EFI is a product of two things: Emissions control and production cost. 4. Six, you keep mentioning "use any carb," which doesn't make sense to me. Carburetors since the early 70s are "feedback" carbs, which control aspects of fuel delivery (choke, metering, altitude compensation, etc) with vacuum sensing. They are not viable in today's market because carbs must be engineered/designed for the engine and application. Particularily in the last generation of carbed engines with "computers" (like my 1990 b2200), you can't slap any old carb on and expect all to be well. Sorry if that's not what you meant. |
#28 (permalink) |
I wish everyone understood that. I find it extremely funny when people bring in kit cars to the shop with 350 SBs swapped in, with a 750 double pumper bolted to the intake
Any reason you chose to go carb'd? For the price of any decent carb, you could buy a MS system and tune away. -Tyler |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#29 (permalink) |
Truth is, I simply feel like sticking this project out. The engine came carbed, and it'll stay carbed. I know, I know. Only 8-valve SOHC, carb is limited output... but my goal is only 200 WHP. Damn it, that british dude can get a V8 to 2200HP.... that's gotta be more than 100% increase in HP. 200HP shouldn't be too difficult and I think I've done my homework.
Right now, waiting on an F2T manifold and I believe I'll have to weld a T3-type flange on it. If things go well, I'll consider upgrading the carb to a Weber or a Holley. |
