Old 7-22-07, 2:20   #1 (permalink)
  Total: 63 Power: 3
SAAB T3 Turbo.
hey, just a quick question
I've got my new manifold and external wastegate setup, and I just want to know if the Saab T3 has the same flange on the exhaust side of the turbo where you would attach your downpipe as I am saving my pennies for a newer garret and just need something to make my car work for Meet of the Mazdas in august and don't want to have to modify my exhaust AGAIN when I get my permanent turbo.
only reason i'm wondering about the saab one is I can pick them up from the wrecker for pretty much nothing, if that flange is different is there a volvo etc that would have a regular T3?
any help is appreciated. thanks so much
boostaddict is offline   Reply With Quote
Old 7-23-07, 11:43   #2 (permalink)
  Total: 928 Power: 5
zlyricist's Avatar
to run any t3 turbo to your stock downpipe, you will atleast have to custom make an o2 housing. the turbine housings are a different style
I'm Zlyricist, and I approve this message
91 GT - 95 LS
06 maxima - the daily
Old 7-23-07, 16:56   #3 (permalink)
  Total: 63 Power: 3
thanks man, but thats not what I am asking. I am well aware the ihi series turbos don't bolt up the same as a t3 in the least.
all i'd like to know is if Saab T3's have the same flange type as regular T3's when it comes to the exhaust outlet.
Old 7-23-07, 19:20   #4 (permalink)
  Total: 919 Power: 5
yeah, if its a 5 bolt. make sure its not a t25 youre looking at, as those are not the same as t3's.
01 Yamaha YZ250
98 Ford Ranger 3.0L
Old 7-23-07, 20:20   #5 (permalink)
  Total: 453 Power: 5
be aware that some of the SAAB T3's have the exhaust inlet flange rotated 90degrees. Some of the 80's 900 series turbo's are this orientation.
Teh Telstar can NEVAH lose!
Old 7-23-07, 20:55   #6 (permalink)
  Total: 919 Power: 5
The exhaust inlet is a snail, it doesn't rotate.
If you mean the exhaust OUTLET is in the same direction as the INLET flange, then ok. I know what style you are referring to.That elbow unbolts, and you can buy a 3 bolt flange that bolts in its place so you can weld up whatever bends you want to it. This is what we did with zlyricists car. He has a flapper housing of that design.
01 Yamaha YZ250
98 Ford Ranger 3.0L
Old 7-23-07, 21:39   #7 (permalink)
  Total: 453 Power: 5
Not the snail itself, but the flange on top. I will try to find a picture for you.
Old 7-23-07, 21:58   #8 (permalink)
  Total: 453 Power: 5
I have only seen one and it was in the wreckers. I'm struggling to find a pic of it.
