All aboard the B& V&
So...tonight I finished putting together my replacement head, and I decided to do a "mock up" of my new exhaust housing, downpipe and T3/T4 57 trim hybrid. Enjoy
![]() ![]() ![]() ![]() Doesn't it just SCREAM over-doing it? ![]() Needless to say, I'm in a pretty ecstatic mood right now. The turbo isn't going to be going installed until later this spring (late April maybe?), but the head's going on this week/weekend. IBy0regoingtoblowshltup |
#2 (permalink) |
i like it, make me one.
also is that the jgs kit? in b4 complaints of log manifold inefficiency. |
My FE3T Project |
#5 (permalink) |
Possibly...if my 'math' is correct...I should be able boost 11psi (1.8 Pr) without any additional help with fuel. I don't plan to boost this monster passed that until I get squirted. Also, spool shouldn't be too much of an issue. The insides are going to house a T3 Stage III turbine, mated with the .63 A/R housing, so I should see full boost about 3.5k rpms in third gear.
#7 (permalink) | |
I'm currently polishing up a stock intercooler (basically getting off the black paint on it) and will be installing that at the same time. I'm also going to be sticking with the stock pipe size for now. I might graduate up to 2" piping all around, but 1 7/8" should do just fine for now ![]() |
#8 (permalink) |
![]() Join Date: Mar 2002
Location: 5900 ft above you aka the highest elevation state in the USA,
CO,
USA
beautiful.
93 Nissan Pathfinder: Remote mounted T3 turbo 01 Yamaha YZ250 04 Suzuki GSX-R600 12.55 @ 115.4 98 Ford Ranger 3.0L |
#9 (permalink) |
heeeyy I know that setup!!! Wonder who got you that d/p and manifold lol
glad to see your puttin git to a good use br0thar. looks just like what I had before teh b00m IBIisgonet0blwshltup ![]() BTW compnut21, if you got teh money, I can get either of those made for you. It WIL cost you, Zach got a retarded deal on them, just cause he's funny ![]() Last edited by alwaysbrokenMX6 : 3-19-08 at 14:10. |
Hi, my name is Broken, and I'm addicted to modding cars. I also reside in Goatcrapp's butthole.
#11 (permalink) |
The d/p flange has a flap for an actuator. Internally wastagated
![]() I still think the best part of that setup is the bung for the O2 OEM sensor. Not having a CEL ftw |
#12 (permalink) | |
Exactly...but I was going to ask, what did YOU do about the EGR? I was thinking of capping the pipe with a nickel/quarter and hoping I don't get a CEL. |
#13 (permalink) | |
Cut the pipe a few inches from where it connects to the IM, pinch and weld it shut. Not too sure what to do about the CEL. But when you go squirted you wont have to worry about it. |
#14 (permalink) |
Mad tizzight, dawg
Good work, now make it come alive and bring it out to the streets. |
Dmitriy (Dima) 1995 Black RS 5 speed, 1995 White LS 5 speed
#15 (permalink) |
I took the pipe out all the way, like, unscrewed it from the IM. Then went to the local home depot or w/e place you can buy a bolt, and looked for an end cap bolt. It screws right in, and with a little loc-tite, is as good as new. As for the egr, you will get the CEL I guess, unless you take the whole system out, i.e EGR valve, solenoid, and cap the vacuums.
I'll try and find the plub bolt Im talking about. I dont think my description was clear enough... |
