Old 3-30-08, 23:50   #1 (permalink)
  Total: 10 Power: 2
boost question
if stock is @ 6psi making 145hp, what would it make @ 10psi?
stupid question, but i NEED to know. thanks
sha-d is offline   Reply With Quote
Old 3-31-08, 0:41   #2 (permalink)
  Total: 145 Power: 2
Keeloh's Avatar
Here read this http://www.mx6.com/forums/1g-mx6-for...yesterday.html (Dynoed again yesterday)
91' Lx to 89' GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/15psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
Old 3-31-08, 21:30   #3 (permalink)
  Total: 10 Power: 2
142 whp @ 10psi?
Old 4-2-08, 15:39   #4 (permalink)
  Total: 10 Power: 2
Originally Posted by sha-d View Post
142 whp @ 10psi?
well, do i have an answer.
Old 4-2-08, 18:20   #5 (permalink)
MX6.com Supporter - Click Here for Information im back from BAN camp
  Total: 342 Power: 4
maffatato15's Avatar
that 142 whp at 10 psi could be many things. Like bad compression for example and it might not be running its full potential. Every car on 10 psi will be different.
And stock is not 6 psi....stock is between 7-8 psi. I believe the wastegate spring might be set for 8.3 psi but dont quote me on this.
1991 lxt
1989 mx6 GT - Daily driver and project car
Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, blitz BOV, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar
Old 4-9-08, 10:37   #6 (permalink)
  Total: 21 Power: 2
ya, im pretty sure that the stock waste gate is like 8~8.5 psi.
stock boost is like 9.8 psi? im not sure, but that is what i believe i remember...
1991 Mazda MX6 GT - 5-speed, Iridium plugs
pyrotech5 is offline   Reply With Quote
Old 4-9-08, 18:59   #7 (permalink)
MX6.com Supporter - Click Here for Information Needs more pie.
  Total: 331 Power: 1
compnut21's Avatar
stock wastegate is 5.5psi. car runs about 9-10 with the boost solenoid fully on.
My FE3T Project
