Old 4-7-08, 22:31   #1 (permalink)
  Total: 10 Power: 2
Gas Light Problem?
i have an 89mx6 gt i am about empty i think im getting 170 to the tank if that. My car has been on E all day but the light hasnt come on yet. I was wondering if the light went out or sending unit. Someone have an idea. THANKS
prbegt94 is offline   Reply With Quote
Old 4-7-08, 22:33   #2 (permalink)
  Total: 770 Power: 3
defiler's Avatar
Pull the dash out and see if the light works.
If so, then thats your problem. If not, then its a gauge or sender problem.
No shortcuts here other than doing some work.
89MX6 GT 4WS
90 Probe GT
If people want to be spoon-fed info, not search, and feel all happy-go-lucky and live in a nice Utopia, then thats what PP is around for.
defiler is online now   Reply With Quote
Old 4-7-08, 22:53   #3 (permalink)
  Total: 10 Power: 2
Alright ill try n do that tomorrow. Thanks
Old 4-7-08, 23:10   #4 (permalink)
MX6.com Supporter - Click Here for Information im back from BAN camp
  Total: 342 Power: 4
maffatato15's Avatar
most likely the light. I had to replace mine not too long ago.
1991 lxt
1989 mx6 GT - Daily driver and project car
Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, blitz BOV, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar
Old 4-7-08, 23:19   #5 (permalink)
MX6.com Supporter - Click Here for Information Needs more pie.
  Total: 336 Power: 2
compnut21's Avatar
you dont HAVE to pull the whole dash. im pretty sure there a connector you can jump in the rear under the seat.
My FE3T Project
Old 4-8-08, 11:42   #6 (permalink)
  Total: 10 Power: 2
i pulled the trim to get to the speedo i unscrewed the speedo and it would only come out a lil bit i couldnt even undo the plug in the back.
Old 4-8-08, 13:52   #7 (permalink)
  Total: 1481 Power: 5
Much much easier to just pull the rear seat and work with the connectors there. The fuel light is on a completely separate circuit from the gauge.
below is wiring diagram, seems to indicate that the wire you're looking for is white with red stripe ("W/R", lower left corner). Find that wire at the pump harness, ground it, turn key to ON, and you should see FUEL light on in dash.
Old 4-8-08, 14:25   #8 (permalink)
  Total: 342 Power: 4
If you have trouble taking the gauge cluster out like i did you might have to do what i did. I took the lower part of the dash and the lower airduct out (which is simple to do) which gave me just enough room to squeeze my hands up there and unplug the 2 connectors and speedo cable.
1991 lxt
Old 4-9-08, 13:08   #9 (permalink)
  Total: 10 Power: 2
Ok well the light works, what else do you think it can be. what do this car get to the tank?
Old 4-10-08, 20:44   #10 (permalink)
  Total: 28 Power: 3
its probably the sender/float. mine does the same thing, i roughly know what i get per tank, but this can vary due to increase/decrease (yeah right!) in fuel prices..
Aiming for the big 200...
89 626 turbo, rebuilt F2T,woo chip,hks ssqv,highflowed T3 ball bearing steel wheel 450hp rated turbo, oil drain straight to sump,3inch stainless dump to 3inch system,fmic,pod, braided oil and water lines, speedflow fittings, 17s,smoked taillights.....next up: Full Respray!
mazdaspeedF2 is offline   Reply With Quote
Old 4-10-08, 21:32   #11 (permalink)
  Total: 46 Power: 4
or how bad you want to beat everyone off the lights for a week
pick_arse is offline   Reply With Quote
Old 4-10-08, 21:51   #12 (permalink)
  Total: 10 Power: 2
where is the sender/float located
Old 4-11-08, 2:22   #13 (permalink)
  Total: 150 Power: 2
Keeloh's Avatar
under the back seat with the fuel pump
91' Lx to 89' GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/15psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
