'89 GT - Did an EBC install - 15psi. No issues?
Have done a few pulls since my install, dialed it up slowly, figuring i would nail the boost cut.
It was chilly last night, plenty of volumetric airflow through the vaf to hit the cut, but never did. 15.1psi according the my peak hold function. Multiple times. Is my car a freak? It's stone stock and i threw on a EBC i was planning on using a higher end vehicle for the hell of it and am very impressed. Thoughts? - Drew |
#2 (permalink) |
the boost gauge is wrong??? A quick spike to 15psi maybe, but not 15psi without a chip.
Gettin blown by one 19yr old...NICE!! Gettin blown by two...PRICELESS!!
89 MX6 Turbo......waiting for the road again....someday....maybe!!! ![]() 89 626 Turbo Hatch....everyday driver! ![]() 89 ZX7 wishing it was turbo...... ![]() Wife's cars- 2001 Echo(driver) / 1991 GT Mustang(summer) |
#6 (permalink) |
i think it is called a hack because it mostly involves shimming the door so it cant be pinned fully back. its basically horrible for your fuel/timing/ecu in general. especially if you raise boost, you can say byebye to your f2t.
raising boost? chip or megasquirt ftw. |
My FE3T Project |
#7 (permalink) | |
I tapped 15.8psi today and finally found the cut.
From there, I had to continuously dial her back, as the cut got lower and lower. Only way i can describe it; It seemed like the car had to 'remember' it had a fuel cut, and once it did she figured out the right number ![]() Now, I can dial in 13.4psi w/o a cut, anything above 13.6psi will cause a cut. So, i am leaving her down around 12psi until i chip her. Quote:
- Drew |
#8 (permalink) |
you live in a high elevation? maybe you vaf is a bit corroded and wouldn't pin back, and now has freed itself. isn't having a mechanical device measure your airflow fun?
My FE3T Project |
#9 (permalink) | |
And yes, archaic. - Drew |
