Old 5-6-08, 1:49   #1 (permalink)
  Total: 10 Power: 1
Tranny Question?
I need a tranny for my turbo 626 just wondering what trannys I can use like do the non turbo trannys work, and the mx6 and probe trannys as well... also do certain ones have shorter gear ratios.... thanks Nick
626_sleeper is offline   Reply With Quote
Old 5-6-08, 2:17   #2 (permalink)
MX6.com Supporter - Click Here for Information Needs more pie.
  Total: 331 Power: 1
compnut21's Avatar
all are the same, except the non turbo ones. they will bolt on, but are weaker.
My FE3T Project
Old 5-6-08, 2:30   #3 (permalink)
  Total: 10 Power: 1
are the gear ratios the same.... I guess I better not use a non turbo if I broke a turbo one lol thanks for the help
Old 5-6-08, 2:33   #4 (permalink)
  Total: 331 Power: 1
compnut21's Avatar
i think so. also to use a non turbo one, or an auto tranny, i think you have to switch hubs/axels.
but all mx6/626/probe turbos with a mtx were the same.
My FE3T Project
Old 5-6-08, 13:45   #5 (permalink)
  Total: 10 Power: 1
I hope not cause I think I might just throw a non turbo in it does anyone know for sure if I have to change the axles
Old 5-6-08, 14:29   #6 (permalink)
MX6.com Supporter - Click Here for Information im back from BAN camp
  Total: 342 Power: 4
maffatato15's Avatar
yes...the axles/hubs differ between turbo and nonturbo
1991 lxt
1989 mx6 GT - Daily driver and project car
Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, blitz BOV, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar
Old 5-6-08, 17:23   #7 (permalink)
Back to the Booster
  Total: 502 Power: 4
cuJe5ter's Avatar
they shouldn't physically fit into the transmission. the turbo ones are bigger IIRC
My Garage
1987 MX-7 Worklog
1988 MX6 GT 14.8 @ 95mph 11psi on stock turbo --- motor going into the RX-7
1988 MX6 GT --- The DD - 2G Front Springs, SSQV, T-bird Hybrid, HKS EVC
1985 Jaguar XJ-6 --- Other DD. Slipping Transmission
cuJe5ter is online now   Reply With Quote
Old 5-6-08, 18:06   #8 (permalink)
MX6.com Supporter - Click Here for Information Non-Turbo 626
  Total: 142 Power: 4
megalomaniac32x's Avatar
the non turbo trans are all the same. the auto are different from NA to turbo and the turbo transis different. the axles are different on the manuals from turbo to NA, same as the hubs and knuckles. i have heard that the autos have the same axles but im not really sure. the 2 manaual trans are not interchangable and also the flywheel and clutch r bigger in the turbo.
http://www.dfwmazdas.com
Old 5-6-08, 20:15   #9 (permalink)
  Total: 10 Power: 1
alright so basically if I just wanna drop a tranny in this thing I want a turbo one otherwise its gonna be a headache
Old 5-6-08, 20:19   #10 (permalink)
  Total: 331 Power: 1
compnut21's Avatar
yes. from another turbo mx6/626/probe.
My FE3T Project
