#16 (permalink) | |
#17 (permalink) |
^^^ Thats coming from the guy who crys about the head design most out of anyone on this site
![]() If there were a thread for every dumbass post on PP, Seans database would be full. -Tyler |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#18 (permalink) | |
I dont think that every dyno that shows the flow dropping off like a rock after 5k or so could be wrong, no matter what turbo was installed... |
#19 (permalink) |
The limiting factor for the F2 engine is without a doubt the lack of aftermarket support.
Thats what seperates it from the KA24 from a 240SX. Well that and 200cc. Or if you want to get technical, from the NISSAN truck KA24. Seeing as how more of the 240SX's got the KA24 DOHC. Last edited by mx_masta : 5-7-08 at 17:08. |
#20 (permalink) | |
It is a function of the engines design philosophy, all focused on low RPM power. (Long runner inlet, long stroke, small turbo) And the overly rich tuning MAZDA used to maintain it's reliability reputation. To say any one of those things is to blame for the F2T's relatively low power is foolish. And with more aftermarket support each would be easily overcome. Last edited by mx_masta : 5-7-08 at 17:07. |
#21 (permalink) |
rod ratio, head design, cam profile etc are not part of the point i am trying to make. i am talking about overall potential. if you want 500hp on just boost in a 2 liter, you need to be able to rev that bitch, the end. pull up a compressor map and plot a f2 at 6K rpms, and then a motor with the same displacment at 8k rpms. the advantage is clear, and cannot be contested
91 GT hy35 build in the works
06 maxima - the daily |
#22 (permalink) |
how the [fizzle] dont i know what im talking about. those stock internals only wish they could see 400 wheel hp... 350 from what ive gathered is pushing it. im very imformed about cars in general i just made a comment see if someone has ever done it obviously the blocks not going to hold 550+ hp so just though it would be a thread to see what people have done.
#23 (permalink) | |
Cams, Solid lifters, Rods, Pistons, Intake mani, Exhaust mani, Turbo, Spark & Management. There is no point in making a point, that while being correct, tells only half the story. To be able to get to the revs high enough to make high hp 2 things are needed. Bottom end integrity = aftermarket parts & high rpm suited inlet / exhaust components = aftermarket parts or DIY - but I don't know too many on here that could DIY an inlet manifold for the correct resonant rpm. DIY is more a case if it's bigger it must be better. |
#24 (permalink) | |||
![]() Gavin |
#25 (permalink) |
Thanks G
#26 (permalink) |
aftermarket is a factor, but definitely not the most limiting factor for overall potential. the f2 will never have the potential of that of a 4g63, or h22, etc regardless of how much aftermarket is available. we can go back and forth all day, but the fact remains
#28 (permalink) |
i think you would be suprised gavin. i belive that is the mentality of a lot of people on car forums, and that is why a lot of people have moved on. as long as people know what they are driving and are realistic about it, then everyone's happy and threads like this dont come about
hell im still happy with the platform after all this time, and probably will be for a few more years, its not a high horsepower 4g63, but its also not something you see every day |
#29 (permalink) |
Back to the Booster
i guess i'll wait "until i know something" to talk to u.
go ahead and spread your "amazing kar gnawledge" while i'm gone. |
My Garage
1987 MX-7 Worklog 1988 MX6 GT 14.8 @ 95mph 11psi on stock turbo --- motor going into the RX-7 1988 MX6 GT --- The DD - 2G Front Springs, SSQV, T-bird Hybrid |
#30 (permalink) | |
The only thing more stupid than your comments is the fact that instead of admitting you have a problem with your facts, you're trying to defend the BS you're posting ![]() ![]() Last edited by defiler : 5-7-08 at 22:32. |
