#3 (permalink) |
thanks, so i will need a 3.5 for the tb. and when i took the stock pipe off that connects the air filter and vaf to the side of the turbo, i noticed that there is a small nipple on the bottom near the side of the turbo that a tiny hose connects to and it comes from the turbo , what is that for, do i plug it or run a breather to it ??
#4 (permalink) |
idk how much it would affect the air mixture if any, but it would suck a little unmetered air in. I know its not enough to make your car run like crap because i had that nipple open you are talking about and my car idled and ran fine. Wouldnt hurt to just plug it up though for the hell of it.
1991 lxt - parting out...ask for parts
1989 mx6 GT -LE Leather seat swap! ![]() Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar, soon to be installed tbird |
#5 (permalink) | |
If you are not using the solenoid just plug it. |
#7 (permalink) |
If you were / are using a manual boost controller.
