Old 5-9-08, 21:47   #1 (permalink)
  Total: 2 Power: 0
Summit Racing ignition?
Do you think i would see any type of gains or any better fuel economy with the new summit racing coil and box?
(gt stock turbo, stock motor)
88 dx/lx/gt hybrid, 89 gt, 90 lx, 91 gt, 92 lx
JAPRACING is offline   Reply With Quote
Old 5-9-08, 21:58   #2 (permalink)
  Total: 2565 Power: 5
.....no.
Originally Posted by r32mx6
Old 5-10-08, 8:53   #3 (permalink)
  Total: 49 Power: 2
I like the way you think six. The stock ignition system is more than efficient for a stock motor. The stock ignition systemes even work extremely well with a bigger turbo bigger injectors.....blah blah blah, you get the idea.Leave the ignition alone and spend your money elsewere.
1989 MX-6 GT
Its ALIVE...after six months... sorta
R.I.P.
1990 MX-6 LX
http://http://www.cardomain.com/ride/2740234
B2000caleb is offline   Reply With Quote
Old 5-10-08, 22:07   #4 (permalink)
  Total: 2 Power: 0
thx i wasnt too sure i was just wondering if it would atleast give better fuel economy or something along those lines.
i have another question too about my gt.the car idles very high like 2000 or above from wat i can hear and where i have sprayed windex and carb cleaner i can see no vacum leak what else could make it idle high?
it had a leakin exhaust manifold gasket when i bought it and it would idle crazily until me and my dad fixed it now it just sticks at 2000. any ideas on what making it do this?
Old 5-10-08, 23:24   #5 (permalink)
  Total: 46 Power: 3
maybe the butterfly in throttle body is a little sticky and not closing all the way
pick_arse is offline   Reply With Quote
Old 5-12-08, 1:00   #6 (permalink)
MX6.com Supporter - Click Here for Information That soldier boy
  Total: 197 Power: 2
professorblaze's Avatar
check the EGR valve. it is on the passenger side of the intake mani toward the bottom.
'89 MX-6 GT - R.I.P 13JUN2008
performance parts for 1g so look here now!
http://www.mx6.com/forums/fs-parting...-my-89-gt.html
Old 5-16-08, 15:52   #7 (permalink)
  Total: 2 Power: 0
thanks ill check some things and see if it helps.
can anyone tell me why my hold light for my atx flashes and sometimes it will stay in hold mode or w/e and sometimes it will only flash? is it a sensor on the tranny bad or something else?
i dont understand how this car has so many problems it only has 88,xxx miles or something.
Old 5-16-08, 18:34   #8 (permalink)
  Total: 452 Power: 5
older car always have problem, 80k miles is when stuff start breaking and warranty is over, if u think this is bad, try a dsm ,
1992pgt.. http://www.cardomain.com/id/ademan
1991pgt..http://img525.imageshack.us/my.php?i...wcar002jn7.jpg
Old 5-25-08, 14:32   #9 (permalink)
  Total: 2 Power: 0
yea so how do i got about checking the egr valve? just remove it and clean it? for the record once the car warms up it seems to idle at around 800 to 1200 but it pulses up on down in between those rpms. i tried messing with the screw in the throttle body to see if it would do anything and it lowered and raised it a little but seemed to not have a big impact can someone tell me how many turns theres is out?
Old 5-25-08, 17:26   #10 (permalink)
  Total: 197 Power: 2
should be able to pull it off fairly easy, just a couple bolts holding it on.
http://www.mx6.com/forums/1g-faq-eng...o-i-clean.html (Where is my EGR valve? How do I clean it?)
Old 5-25-08, 21:53   #11 (permalink)
  Total: 2 Power: 0
so clean my egr valve and see if it gets better? if it does not improve wat do you think i should do? there is now vaccum leak i could find with carb cleaner or could hear any more ides?
in that how to it says to reset the ecu what will that do? do you think if i reset the ecu without cleaning it would have any effect on the crazy idle
Old 5-26-08, 2:20   #12 (permalink)
TURBO
  Total: 45 Power: 2
check the idle screw on the throttle body
BlueInfinity48 is offline   Reply With Quote
