clutch options
what options are out there for aftermarket clutches? something that will hold 300 HP or more, and where is the cheapest place to buy them.
88 626 GT- daily driver with some mods
90 subaru legacy- former DD, rally project? 86 rx7-ported,3mm seals,bnr stage 4, haltech 87 rx7-NA with some mods |
#2 (permalink) |
91 Lx to GT Swap/T-Bird Turbo/Zebel Housing/2.5" Downpipe,Test Pipe,Sebring Exhaust/Probinator Chip/14psi/Walbro 255LPH Fuel Pump/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Fidanza Aluminum Flywheel/Exedy Clutch/AWR Mounts/AWR Trailing Arm/GT Rear Disc Conv/Subaru Front Dual Calipers/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats with 4 point Harness.
#3 (permalink) |
Indeed, Keeloh is correct.
Ask for Andy, and mention that you are from mx6.com, you ought to be nicely surprised. ![]() I got an OFE Stage 3, but you probably need something with a bit more beef to it.. for 300 whp,y ou are looking at 350 ft/lbs of torque at least, if not more... |
#5 (permalink) |
for the love of God!!!! STAY AWAY FROM THE "GRIPFORCE" clutches on ebay....they wouldn't hold up under the torque most riding mowers put down!!!
'90 pgt.....the usual mods
...........ps....I don't ask questions prior to searching Founder of the home for the grammatically challenged .....few pics of my baby!!... http://s212.photobucket.com/albums/c...izzo90_photos/
#7 (permalink) |
I am using an Exedy MZK-6806SO (sports organic) its basically the same as the standard clutch except its got 1950lbs of clamp force, as opposed to about 1200lbs on the standard.
All mated to a fidanza flywheel. Its a good compromise for a daily driver with 200-250hp There is a guy here in Oz who modifies a B2600 plate to fit so that you can get up 2600lbs clamp....I was going to get that, but couldnt really wait to have it made up...I had to go the off the shelf option.... |
89 626 5 door F2T 90 323 sedan B6 SOHC Slug-o-matic DD |
