Old 5-15-08, 11:33   #16 (permalink)
  Total: 2594 Power: 5
All turbochargers do that regardless of being "off boost". It's cast iron and it heats up. I would still check my timing and cat if I were you though.
Originally Posted by r32mx6
Originally Posted by SixSick6
u mom smoke a dose pipe.
Old 5-15-08, 11:43   #18 (permalink)
.....lol...maybe not as easy but that shouldnt be hard for you to accomplish
Old 5-15-08, 12:07   #19 (permalink)
  Total: 1176 Power: 5
fredio54's Avatar
LOL, that's what I was thinking :-) The bigger freer exhaust etc should help it stay cooler. But I'll be doing static burnouts with the bonnet off just to see that happen :-)
Old 5-15-08, 19:44   #20 (permalink)
MX6.com Supporter - Click Here for Information Needs more pie.
  Total: 336 Power: 1
compnut21's Avatar
Originally Posted by fredio54 View Post
LOL, that's what I was thinking :-) The bigger freer exhaust etc should help it stay cooler. But I'll be 250kph down the freeway at 30psi.
fixed. 8
My FE3T Project
compnut21 is online now   Reply With Quote
Old 5-15-08, 20:02   #21 (permalink)
  Total: 15 Power: 2
The first mx6 gt that I had would get really hot in the same area. It cracked the area around the wastegate opening and had to be trashed. But as stated above some glowing is normal on turbo manifolds due to the extreme heat build.
ugly mx6 guy is offline   Reply With Quote
Old 5-15-08, 20:02   #22 (permalink)
  Total: 376 Power: 3
alwaysbrokenMX6's Avatar
I was gonna say that it sounded pretty normal, but I guess thats settled. I would suggest, however, that if you dont have one, you get yourself a turbo timmer, and set it up to a 1 min or so cool time. It should save yourself a lot of hassle later.
Hi, my name is Broken, and I'm addicted to modding cars. I also reside in Goatcrapp's butthole.
Originally Posted by Trent
uhh.......the 2G Appearance section IS the rice forum.
alwaysbrokenMX6 is offline   Reply With Quote
Old 5-21-08, 14:23   #24 (permalink)
  Total: 11 Power: 0
injectors ok?
how is the fuel mileage? any bad smells, maybe injector is bad and pouring raw fuel through, this is main reason cat's burn out prematurely. i have seen a product that is a fuel additive advertised as a catalytic convertor cleaner, hope these ideas help, hate to see somebody change the cat only to ruin it again by not fixing the root problem...
liter is offline   Reply With Quote
Old 5-21-08, 15:28   #25 (permalink)
  Total: 273 Power: 4
vrouv06's Avatar
hahaha i've done that before. Turned out I had my timing to advanced. Those cat cleaners (aka Sea Foam) won't fix your problem though. If your cat is clogged then there is nothing you can do really but replace it. If it's a rich problem the catalyst will just heat up so much that it will melt, thus clogging your cat. Same thing if it's a timing problem. If your cat is clogged you'll know it. It's an unmistakable feeling and sound. One day you'll be driving and it'll go pop and you'll have your power back. Sounds like a timing issue to me though. How's your exhaust smell?
vrouv06 is offline   Reply With Quote
Old 5-24-08, 11:32   #26 (permalink)
  Total: 10 Power: 2
I think this is pretty normal for turbos. every car iv had that was boosted has done the same thing. And I dont know a whole lot but id say your running a little lean to create this kind of heat if your not pushing crazy boost. Also invest in a turbo timer or you will get lots of built up burnt oil.
Luke
sfmx6 is offline   Reply With Quote
Old 5-25-08, 13:10   #27 (permalink)
fredio54's Avatar
CaseJunkie's, and it was a LOT more obvious in person. The whole mani and turbo were all glowing.
