Old 5-15-08, 22:56   #1 (permalink)
Oil Filter Question
Just wondering if anyone is using a larger oil filter. I got one for a ZR 1(I think), but have not installed it. Seems it has a lot less gasket touching the block. Anyone had any luck with these? Is there another larger filter that will work on a '90 turbo?
Two more hours of this play, somebody shoot me!
Abraham Lincoln
slime is offline   Reply With Quote
Old 5-16-08, 8:53   #2 (permalink)
  Total: 11 Power: 2
There are two filters from mazda that will fit, one is a very small one that looks too small and the other one is about 20 percent bigger and is alot easier to work with as far as getting it on and off the engine. Most of the aftermarket ones are even bigger than the larger one from mazda.
ugly mx6 guy is online now   Reply With Quote
Old 5-16-08, 13:00   #3 (permalink)
  Total: 25 Power: 2
I have a larger filter on my '90 MX-6, but I don't know the part number off the top of my head. The good news is you CAN put a larger filter on, and it makes a huge difference in how much longer your oil stays clean, I would definitely recommend it.
Ragnarock01 is offline   Reply With Quote
Old 5-16-08, 21:35   #4 (permalink)
Yes, the ZR1 filter is a lot bigger. I'm just concerned about a gasket blow out because only part of it is in contact with the base. I used '86 626 turbo (I believe) filters on my 323 GTX and my '99 miata because they were bigger. Just have not found an upgrade for the stock GT filter yet.
Abraham Lincoln
Old 5-16-08, 23:31   #5 (permalink)
  Total: 15 Power: 2
When you say "ZR1", is it a Chevy Corvette ZR1? And what year?
mrmoose is offline   Reply With Quote
Old 5-16-08, 23:38   #6 (permalink)
MX6.com Supporter - Click Here for Information That soldier boy
  Total: 197 Power: 2
professorblaze's Avatar
i spent almost an hour doing this in shucks a few days ago. the filter for a speed6's gaskets line up but I don't know if it will fit cause the center section sticks out a little more than the 1g 6's.
'89 MX-6 GT - R.I.P 13JUN2008
performance parts for 1g so look here now!
http://www.mx6.com/forums/fs-parting...-my-89-gt.html
Old 5-17-08, 8:23   #7 (permalink)
I think it was a 1990, but all those years had the same engine.
Abraham Lincoln
