Old 9-22-09, 20:58   #1 (permalink)
  Total: 10 Power: 1
Forged Internals or not?
I have a 92 ford probe gt 2.2 turbo and i need to know what internals are in the motor. Are the pistons forged (i assume they are) and are the connecting rods forged. I have plans for the motor but i need to know what is in the motor and how much boost can the motor take. Also how much hp can the 5 speed trannsmission take.
ncsdaonex is offline   Reply With Quote
Old 9-22-09, 22:27   #2 (permalink)
  Total: 431 Power: 5
Nothing in the F2T is forged. The pistons are hyperutectic (prob spelled wrong) cast AL.
The engine is strong though, pretty much stronger than the head can flow and definitely stronger than the trans.
As for the transmission, you can break one on a stock turbo - Ridiculous tq spike from the small turbo + hard enough driving. If your tq/power comes on a bit smoother it can hold a decent amount.
*edit* - rods are forged, see page 2...
My IHI turbo page
Old 9-23-09, 8:21   #3 (permalink)
  Total: 10 Power: 1
So if eventually i get 15 lbs of boost will the stock motor take it?
Old 9-23-09, 8:34   #4 (permalink)
  Total: 246 Power: 3
Yes it will handle 15psi. Ppl here have run above 20 psi on a stock motor. Like n2o_matt said engine is strong.
[fizzle] what other people think.
Old 9-23-09, 10:32   #5 (permalink)
  Total: 366 Power: 5
the stock motor can easily handle 15 psi on a much larger turbo if the proper tuning is done. hell, with the right tuning, it could handle alot more. but it all comes down to the tuning. dont even worry about the motor yet.
~ChiPoC~
Old 9-24-09, 5:36   #6 (permalink)
STW
  Total: 505 Power: 4
STW's Avatar
Sure the rods are not forged? In other FE variants they are; they just are in the classic I-beam shape and evidently nothing too special, but still.
1988 626 GT Wagon, 2.0 DOHC Turbo | 1992 Toyota Carina e GLi | 1991 626 GLX Hatch AWD 2.2l
Old 9-25-09, 6:58   #7 (permalink)
  Total: 10 Power: 1
def not forged . Got a couple of ruined ones from excessive heat/leaning out the engine on 15pse with a t3
qik626 is offline   Reply With Quote
Old 11-1-09, 11:34   #8 (permalink)
  Total: 15 Power: 1
^^ so their not forged because youve ruined a couple? you can brake forged rods.....
Click Me!!!!!<------ My Car
baardoon is offline   Reply With Quote
Old 11-1-09, 18:45   #9 (permalink)
SD6
  Total: 729 Power: 5
SD6's Avatar
They're not forged, I was just looking at a set the other day.
They are however, just as beefy as 1G DSM rods, when compared side-by-side. I know this isn't exactly the most quantitative measurement of durability available, but it's good enough for MX6ers
98 GS-T Spyder
SD6 is offline   Reply With Quote
Old 11-1-09, 19:02   #10 (permalink)
  Total: 285 Power: 4
The crank is forged and strong enough for anything you are likely to make with the 3 valve head, I would think the rods would be also as most Mazda along with most Jap 4 bangers come with forged rods. Not really to make them stronger than cast rods but to allow them to be lighter than cast with similar stregnth.
Forged rods also tend to bend when they fail rather than break, thus sparing the rest of the motor from utter destruction.
Old 11-3-09, 4:23   #11 (permalink)
  Total: 70 Power: 3
f2 rods are much more beefy than 1g DSM rods and are definately not going to be the weak link in the engine. The only reason to replace them would be to save weight on the rorating assembly because I would guess they will stand more power than the head can flow.
GT3782VA VGT, FMIC, custom 2.5" hardpipes, ching chong BOV and 38mm wastegate, 2.5" exhaust...MS2Extra, Boost, oil pressure and EGT autometer guages. LC1 Wideband
http://www.mx6.com/forums/1g-mx6-for...ml#post2168882
SiFlyBy is offline   Reply With Quote
Old 11-3-09, 22:35   #12 (permalink)
Shove it!
  Total: 1884 Power: 5
Zach's Avatar
I believe the rods are forged and the crank is cast...check the casting lines on both parts.
From my understanding, thick "cast" line = forged, thin 'cast' lines = cast. Am I wrong? If I am, please take a look at the forged RF diesel crank...check out that thick 'casting' line.
postin tryna get you booted
Parting out Gray 89 GT
Originally Posted by Kansas
Old 11-4-09, 8:51   #13 (permalink)
  Total: 366 Power: 5
i didnt think any of our motor was forged. i know the crank isnt from the last time i had one machined. but the machinist did say that for not being forged, its one of the harder steels he's had to machine. guess he went through a few bits on it.
~ChiPoC~
Old 11-4-09, 13:11   #14 (permalink)
Shove it!
Zach's Avatar
the line on the rods is pencil thick, maybe a bit more and the line on the crank is paper thin
Old 11-4-09, 18:43   #15 (permalink)
STW
  Total: 505 Power: 4
STW's Avatar
Anyone got a photo of an F2 rod? I can't get to any engine work until next week at the earliest, and by then I should have an F2 lying around that I can tear down for a peek inside..
