Garrett t3/t04e 60trim. 5bolt downpipe. 60ar compressor and 82ar exhaust
Used for 150 miles befor the engine blew. The shaft spinns perfectly and there is no in and out or side to side play.
Compressor Specifications:
-60 trim T04E compressor wheel with a max flow rate of 53 lb/min
-0.60 AR T04E compressor housing
Turbine Specifications:
-stage 3 turbine wheel
-0.82A/R. turbine housing
-5 bolt standard turbine discharge
-270 degree thrust bearing standard
I traded my Holset HE351CW for it. I didnt want to see it go to waste and i couldnt sell it. This will still meet my needs easily. It is going on my stroker 2.2 FE.
By
lundgren420000 at 2009-10-05
By
By
By
By
lundgren420000, shot with
FE100,X710 at 2009-10-05
By
Thanks. Nixapgt from PT.
