#32 (permalink) |
depends on what type of supercharger you are talking about. there are three different types. technically two of them are almost the same. there is the centrifugal type, roots type and a screw type. the last two are what they call positive displacement chargers and they produce power right off of idle. the centrifugal one is like a turbo in that as it spins faster it makes more boost. the limit of this supercharger is the rp range. the roots blower doesn't actually "compress" the air. just shoving more air into the motor and the screw type does what the roots one does but while also compressing the air.
#34 (permalink) |
or you could use an MSD 6BTM, but all of this superturbocharger talk is insane. maybe not for larger motors..but for the 2.2..and the amount of limited engine bay space and constraints of the head itself..... this...supercharger/turbocharger/superturbosupercharger talk is pointless
#35 (permalink) | ||
Do you really think, honestly, that in the space of one thread you are going to revolutionise forced induction for the world? Really? When I was 12, I had a dream of making an internal combustion engine out of wood and tin foil, my only stumbling block was how to make iddy biddy tiny little spark plugs......well, that, and the fact that my idea WAS JUST PLAIN STUPID. You need to except that same fact, and move on. A turbo was never designed to take lateral load on the shaft, it won't work, accept it. That's why Garrett don't make an adaptor to replace the turbine housing with a pulley, don't you think if it were a good idea that Garrett or any one of the turbo manufactures would have considered it. Or are you smarter then all their R&D teams. When you float such a ludicrous idea on a open forum you need to brace yourself for a bit of negativity, that's life, I'm guessing you're very young. EDIT*oh my god, you're 26 that kinda makes it worse.* Do you really find that lag is a problem with our engines, I don't. What mods do you actually have to your engine, have you exhausted (pardon the pun) all conventional methods of improving TC performance? I'm going out on a limb here and guessing "NO". Last edited by crusty : 3-31-04 at 17:09. |
When they outlaw freedom, only outlaws are free
#36 (permalink) |
hmm i'm just replying to the original post, the idea to have a injector in your exhaust manny is just plain crazy, i don't know how safe i'd feel about putting a fuel line going right on your exhaust many..... but it did spark another idea(no pun intended), how bout water injection into the exhaust manny... basically at the right amount it would instantly vaporize expand and cause more pressure through your exhaust... sure it probably would be very compliucated having a system that starts dumping water at the right manifold temp and maybe right engine speed too... ect... Probably way too much work to test something like this out....
#37 (permalink) | |
Q.Where does that get you? A.back to square 1 The thought of driving down the road with steam billowing out the exhaust doesn't really appeal to me either. Nor the idea of squirting cool water on a red hot piece of CAST iron. can you say, "crack"? The recognized way of reducing lag in a tc engine is to inject NO2, whats wrong with just doing something that works. Next thing we know 85GTS will be asking if anyone has any ideas for a different shaped wheel.....maybe a triangle. Last edited by crusty : 3-31-04 at 20:28. |
#42 (permalink) | |
either vortech or paxton. and why would a TURBO company have R&D on SUPERCHARGERS anyway. |
#43 (permalink) | |
Fluid bearings won't be able to do that. |
#44 (permalink) | |
The biggest drawback of the centrifugal supercharger is it's inability to make high levels of boost at low engine rpms. Typically, a centrifugal supercharger will make it's maximum (quoted) boost at the engine's redline rpm and nearly nothing at 1500-2000 engine rpm. Boost builds exponentially with engine rpm, meaning that boost comes on very quickly in the upper half of the powerband. http://rcspoolers.com/cent_sc_explain.htm So hows that going to help your lag issue? Google is your friend. |
