Old 2-17-05, 12:19   #16 (permalink)
  Total: 339 Power: 5
Originally Posted by MazdaMiester
alright lets see what i can add in here:
What: Passenger Under-seat tray Slider drawer from 89-92 PGT
replaces factor sub box.
Modification req'd : mounts in same location(for those who dont use that subbox due to aftermarket stereo) No drilling required, However it will not fit DX seats. You'll need both brackets and the drawer, thats it!
Get more storage room!
What: Aluminum rx-7 Scissor jack. For those who want to lose a few pounds but still have a jack, one weighs about 3-4lbs compared to the nearly 10 our stock one weighs, fits in the same spot, no modification required
What: Aluminum 16X5 5-lug Rx-7 Space saver. Weighs alot less then our stupid tiny steel ones, looks alot better... Fits perfectly in the trunk
Found on: All rx-7 convert's, 87-91 rx-7 Turbo, and 89-90 rx7 GTUs<(not just GTU, has to be a GTU-s)-Eric
damn it, i have all three of those done, and didnt even think about it, u forgot to mention the rx7 jack also raises the car a few inch's taller. the under seat tray is GOD!!!, my 89pgt has mx6 seats installed, but i wanted to keep the drawer, and yes, its as simple as bolting it in, and it gives u more room then the glove box.
~ChiPoC~
Old 2-17-05, 13:06   #17 (permalink)
  Total: 117 Power: 5
AWR sells a rear trailing link......
Originally Posted by monoxidechild
u can actually take the whole 2nd gen suspension, and bolt it to a 1st gen. next phase im gonna do is a full 2nd gen set up on my 92pgt.
Does this mean the rear links for a 2nd gen bolt up to a 1st gen? Did they use the same rear suspension on both generations?
1989 MX-6 GT. ORIGINAL OWNER!! 237K on the original clutch, K&N drop-in, Gillis boost valve, Tokico Blues, Mazda RSTB, Energy Suspension poly sway bar bushings, end links, tie rod end boots, AWR poly motor mounts (VIBRATION!), Mazda rear lower tie bar, PGT rear sway bar. BRAND NEW stock turbo ready to install!
mlp-mx6 is offline   Reply With Quote
Old 2-17-05, 14:14   #18 (permalink)
  Total: 1533 Power: 5
Read a bit more into the words. "u can actually take the whole 2nd gen suspension" ..means the struts ,the suspension linkages of the 2nd gen are not the same as the 1st gen. (for the trailing link you mentioned the 2nd gens is a bit longer)
Even referring to the struts is a bit misleading because the 2nd gen struts are not a direct fit. They can be made to fit with slight modification however. This has been gone over many times.
Gavin
Old 2-17-05, 14:32   #19 (permalink)
  Total: 673 Power: 5
mx6GT91's Avatar
What: Cupholders
Donor Car: 92-95 Ford Taurus
Modification required: None
Why: The MX6/626 lacks cupholders, which some people find valuable. Not an upgrade per se, but a nice creature comfort.
Not sure if they'll fit but it looks to be about the same size.
89-94 Maxima cupholders look a lot cleaner. Push it and it slides out (in a sexy way I'll add) showing off a big den for storage. Then another cover slides out with holes for cups.
I installed one on my friends Sentra. I must say its something Im getting.
Anyone want a NICE 1G? :-/
mx6GT91 is offline   Reply With Quote
Old 2-18-05, 9:16   #20 (permalink)
  Total: 177 Power: 5
Thumbs up 2 pot front calipers!
How about the subaru legacy 96 I believe. Can swap the caliper with our front ones keeping our stock bracket, Therefore retaining stock pads. They are 2 piston for an even distribution of clamping for on the pads. Modification= None. although not the slider pin on subie is longer than stock, just change them out.
If I'm mistaken feel free to correct me, I got the info from gavin's brake write up.
Thanks Gavin,... I just wish I didnt have to pay the damn core chargelol
http://www.mx6.com/forums/showthread...ins+brake+post (Gavins MEGA brake job(and a whole lot more))
ADAM
Mx6MaZTer is offline   Reply With Quote
Old 2-21-05, 0:32   #21 (permalink)
The Mod With the Mostest.
  Total: 1076 Power: 5
Panther37's Avatar
If you guys see anything you want to comment on, just comment on it here. This thread is gonna get big. In a month when most of this stuff is "agreed upon" It will be made it's own thread in the FAQs. Please quote and confirm anything you see up here for validity.
Old 3-23-05, 1:21   #22 (permalink)
  Total: 100 Power: 5
The rear 2g springs DO work on the 1g struts (I just finished this a few days ago). The 2g springs on the rear are slightly smaller, but once everything is lined up and mounted, the spring does not move whatsoever...there is no safety concern because if the spring were to move it will still be caught by the lip on the strut.. The difference in diameter is maybe an inch overall, possibly less. Fronts are 100% the same.
EDIT UPDATE>>> 1200 miles on them, and they are still fine. The springs have not moved ONE BIT.
***1992 MX-6 DX w/220k miles 17.99@ 32mpg
***1991 300zx Twin Turbo 5 spd. 10.76@133mph
***2004 V35 Skyline 350GT 6spd. Procharged.
ZFreak-MXSix is offline   Reply With Quote
Old 3-27-05, 5:45   #23 (permalink)
  Total: 11 Power: 5
can any1 else verify that this is doable and safe?
88 MX-6 GT
Spoolin'S12 is offline   Reply With Quote
Old 3-27-05, 16:14   #24 (permalink)
  Total: 403 Power: 5
Other people have done it.
I did a search, found a few.
So I assume so..
Im going to do it my self.
94'LS KLZE,S-AFC,MSD6AL,SS-Headers,2.5" CB,CM Stage3,MX3 FW,CAI,Probinator chip,Konig 15",RRMounts, Illuminas, Sprint Springs, Brembo Slotts Rotors, Hawk Pads.
Old 3-30-05, 13:03   #25 (permalink)
  Total: 339 Power: 5
its been doen for years with no issues, my 89pgt had 93pgt springs on it till last weekend when i upgraded to the dropzone springs from a 95 pgt. its not something that needs argueing over, believe me, they drop in, its that easy.
but 2nd gen coil overs DO NOT work
~ChiPoC~
Old 3-31-05, 3:35   #26 (permalink)
  Total: 11 Power: 5
so if i buy after market springs or stock springs from a 2nd gen it should work fine on my 1st gen right? sorry i just wanna make sure cuz and i don't want to [fizzle] up a almost perfectly good car
88 MX-6 GT
Old 3-31-05, 9:22   #27 (permalink)
  Total: 339 Power: 5
yes, they will work, but 2nd gen coil overs will not work, they dont fit the rear struts right. unless u go with a set of 2nd gen struts also
~ChiPoC~
Old 4-12-05, 21:14   #28 (permalink)
  Total: 2583 Power: 5
The IHI RHB5 VJ5 will serve as a replacement for the VJ11 if you replace the vj5 with vj11 coolant lines.
Originally Posted by r32mx6
Originally Posted by SixSick6
u mom smoke a dose pipe.
Old 4-12-05, 21:37   #29 (permalink)
Panther37's Avatar
Yes, but what will be the performance difference?
Old 4-15-05, 0:43   #30 (permalink)
Ah, good point!
Nothing:http://www.mx6.com/forums/showthread.php?t=124920 (IHI RHB5 VJ11/ IHI RHB5 VJ5 Comparison..Just for you Kirk!)
