#33 (permalink) | |
NOTE: had to grind down the sill on the strut so the coil-over would slide over it. Once this was done, was a nice, snug fit. Drop could be more if I wasn't riding on bump-stops (which are cut in half anyway). No way to avoid this without raising it or seriously modifying struts.... Last edited by dope : 5-26-05 at 7:21. |
\--/ l |--| TX5....... got toe? |
#34 (permalink) |
Are the fuel tanks in the MX-6, 626 and Probe interchangable?
-The tanks in the GTs and N/As do not differ. A GT tank would fit into a N/A Mazda/Ford. Yes. Heres some pics for proof from a fuel tank book at work. ![]() ![]() Showing capacities of both tanks.-Tyler Last edited by tyler886 : 10-4-05 at 22:03. |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#35 (permalink) |
update on the springs...
I have about 8,000 miles on them now and still no camber issues, no fitmetn issues, etc. The springs haven't moved (2nd gen rear springs on 1st gen struts). They are the dropzone springs from the 2nd gen's. No probs whatsoever. Stiffer than stock though.
***1992 MX-6 DX w/220k miles 17.99@ 32mpg
![]() ***1991 300zx Twin Turbo 5 spd. 10.76@133mph ***2004 V35 Skyline 350GT 6spd. Procharged. |
#36 (permalink) |
92-95 Civic Short Throw Shifter.
Ive had mine in a LX and my GT for over 50,000 KMS and had no issues so far. |
94'LS KLZE,S-AFC,MSD6AL,SS-Headers,2.5" CB,CM Stage3,MX3 FW,CAI,Probinator chip,Konig 15",RRMounts, Illuminas, Sprint Springs, Brembo Slotts Rotors, Hawk Pads. |
#38 (permalink) |
heres a similar thread on PT that covers quite a bit more then has been mentioned here.
http://forums.probetalk.com/showthread.php?t=1701141029 |
~ChiPoC~ |
#39 (permalink) | |
i gave jiffy my gas tank from my PGT for his mx6 and it fit right in. all pieces the same |
91 626 DX, 89 F2T swapped, probinator chipped ecu, 2.5 inch exhaust and downpipe, zebel housing, 10 psi, mazdaspeed FSTB, blaster2 coil, pacesetter sts, rstb and lower tie bar, suby calipers, rear disc brakes, PGT rear swaybar, eibach springs, MSD SCI
http://www.cardomain.com/ride/2146610 http://www.dfwmazdas.com |
#40 (permalink) |
hey so will 93-94 mx6 springs work on a mx6 dx and if so do they lower the ride, sorry about reasking a question i just didnt see any1 say if dx struts are different then gt or lx in size or somthing, 89 mx6 dx
R.I.P. Silver 89 Mazda MX6 DX
White 90 Ford Probe GT Chipped ECU, Cone filter, Gutted Cat. Boost controller, BOV set-up, Rebuilt Engine, Twin canister fart pipe, JL Audio 12" W1 V2 on JL Audio 500/1 Mono |
#41 (permalink) |
Back to the Booster
been a while since any updates here but i found one i believe to be worth it.
What: Ignition Coil Holder (canister style) and rubber boot Donor Car: 88 Audi 5000 (idk what years used this style. this is the one i took it off of) Modification required: some drilling and finding a place to mount it. the boost just slides over the whole canister to cover the positive/negative terminals Why: For those upgrading to a performance coil (msd blaster 2, accel, crane, etc.) |
My Garage
1987 MX-7 Worklog 1988 MX6 GT 14.8 @ 95mph 11psi on stock turbo --- motor going into the RX-7 1988 MX6 GT --- The DD - Stock + HKS SSQV |
