Old 11-17-06, 11:44   #61 (permalink)
Strong Arm Mod is Strong
  Total: 1576 Power: 5
Zach's Avatar
I have to get my car running good beforehand...but I'm not opposed to it. I might just run them stock, without an FMU. I might get ahold of Jeremy and see if he can burn me a chip??
Build My City and Instrusty Up! <<<<Click It!
57 trim spoolin' at 12mph
My Retrofit Thread!
I think goatcrapp is the frickin MAN!
Zach is online now   Reply With Quote
Old 11-17-06, 11:46   #62 (permalink)
  Total: 880 Power: 5
zlyricist's Avatar
i have a set of those injectors and according to brandon (rebel2k4) they work just fine. those are the rx7 injectors have an oval style connector that will only connect to 90-92 style i believe. please correct me if i'm wrong
91 GT - 350whp coming sooner or later
92 626 - pos 400$ daily
Old 11-17-06, 11:48   #63 (permalink)
Zach's Avatar
$20/apiece
http://cgi.ebay.com/ebaymotors/1986-...spagenameZWD1V
My Retrofit Thread!
Old 11-17-06, 11:59   #64 (permalink)
  Total: 880 Power: 5
zlyricist's Avatar
i got me a used set from a member on rx7club.com, 50 shipped for all 4
his name is bridgeported, and i think he might have more
Old 11-17-06, 12:01   #65 (permalink)
  Total: 328 Power: 5
Jake's Avatar
460 cc injectors
You are right and wrong. The 195500-1350's which Hostasst points out in his post below yours, have SQUARE connectors and will go right into the 88-89's.
I am holding one in my hand as I type.
I think it is the 195500-2010's that you are referring to, with the oval connectors. But they should work too as long as you can splice in the oval clips. THey are both 460 cc high impedance.
The 88 rx7 used the 1350's and the 89 and up used the 2010's. This is according to rebel2k4.
4WS.ORG (4 wheel steering)
l
U-turn in the driveway!
Old 11-19-06, 18:53   #66 (permalink)
  Total: 523 Power: 5
Someone left a few important things out. You need to go by the color of the "Top" (the female plastic connector) on the injector AND the part #. From 1988-on, they were all High Impedance, while the 1988-only injectors had the square plug/connectors (identical to our 88-89 connectors).
While the Part# 195500-1350 (460cc) comes in High Impedance, that same exact Part# comes in Low Impedance (1986-1987 models) also. Same is true for the 550's (Part# 195500-1370) between the '86-'87 and '88 injectors. Same Part#, different resistance.
Now to distinguish whether they are High or Low Impedance, you need to look at color of the "Tops". The 1988-only 460's and 550's both came in only Purple Tops and the 86-87 460's are Red Tops and the 86-87 550's came in Tan/Light Brown Tops.
Remember, the '86-87 and '88 injectors share the same part number and connectors ("pigtails"), but have much different resistance. This is the best way to distinguish whether you're getting low or high resistance.
Your best bet is to find '89-'91 injectors in 460's (part# 195500-2010 - RED TOP) or 550's (part# 195500-2020 - PURPLE TOP) to reduce all this confusion. These injectors do have the oval top, which plugs right into our 90-92 connectors (pigtails). I prefer these style of the tops, because it is much easier/quicker to remove the connectors from the injectors instead of taking off each retainer clip on the connectors to remove the connector.
1989 MX-6 GT - SOLD
T3/T4, MegaSquirt 'n Spark
cenatix is offline   Reply With Quote
Old 11-20-06, 9:31   #67 (permalink)
  Total: 328 Power: 5
Jake's Avatar
What color is your top
Originally Posted by cenatix View Post
Someone left a few important things out. the connector.
Wow I think you just confused them even more...
Here is a FLAWED color chart that is sometimes correct that people seem to refer to:
Low- 1.7 to 3.0 ohms (Peak and Hold Driver/Injectors)
High- 10 to 16 ohms (Saturated Circuit Drivers/Injectors)
1986-87 RX-7 195500-1350 Peak and Hold 460cc Red Top
1986-87 RX-7 195500-1370 Peak and Hold 550cc Tan Top
1988 RX-7 195500-1350 Saturated 460cc Purple Top
1988 RX-7 195500-1370 Saturated 550cc Purple Top
1989-91 RX-7 195500-2010 Saturated 460cc Red Top
1989-91 RX-7 195500-2020 Saturated 550cc Purple Top
Now, having read that...
I just checked a red-topped 195500-1350 I had here and it is NOT Peak and Hold (low impedance) DOH!!!
So the colors are NOT always correct! Stupid Denso. It would appear that they ran out of Purple and switched to Red resin 1/2 way thru making the 195500-1350's!!! When I called and asked them about it, they said, "Why are you trying to put RX-7 injectors in an MX-6? " ( I hung up while mouthing "mutherf**kers").
So I called witchhunter.com. They do nothing but rebuild injectors. He said "Denso is stupud. Forget the color, go by the notch."
On the square connectors, if the notch/indentation on the OUTSIDE of the connector is offset, it is HIGH impedance. Mine was offset to the right. If the notch is in the center (not the notch inside the connector), then it is the low impedance connector. The BOTTOM line was, if it plugs into your stock harness, then it is correct for your car's ECU.
l
Old 12-9-06, 0:22   #68 (permalink)
  Total: 9 Power: 3
anybody know if a civic rear lower tei bar will work
kuppa is offline   Reply With Quote
Old 1-25-07, 20:34   #69 (permalink)
  Total: 2555 Power: 5
Look here Jake:
http://www.injectorsonline.com/indivprod.php?c=6
Originally Posted by r32mx6
Old 1-26-07, 11:13   #70 (permalink)
  Total: 328 Power: 5
Jake's Avatar
Originally Posted by SixSick6 View Post
Okay why am I looking there?
They dont show you the notch.
l
Old 1-30-07, 12:47   #71 (permalink)
  Total: 880 Power: 5
zlyricist's Avatar
i believe i have some of these (1988 RX-7 195500-1350 Saturated 460cc Purple Top) at home, if it helps i can take pics of the connectors
Old 5-19-07, 21:17   #72 (permalink)
  Total: 10 Power: 0
Are there any transmission thrust washers which would be compatible with the g4a-el tranny? I can't find a set anywhere.
b_harris265 is offline   Reply With Quote
Old 6-20-07, 13:50   #73 (permalink)
Zach's Avatar
For anyone that's posted in this thread, is the headlight combination switch interchangeable between 1gA and 1gB ? ? I knock on my steering wheel and my brights come on
My Retrofit Thread!
Old 6-20-07, 18:34   #74 (permalink)
  Total: 880 Power: 5
zlyricist's Avatar
mine worked fine for me going from a 1genb to 1gena. except now i have an ugly orange button sticking out the end of my combo switch. reason i switched mine out was cause my brights were jacked
Old 6-20-07, 18:35   #75 (permalink)
Zach's Avatar
lol....I like the orange cruise knob. it's serious bidness.
I think I might perform surgery so that the high beam flash doesn't work when you pull back. it's just three pins I need to pull.....
My Retrofit Thread!
