#76 (permalink) |
MPV Blower fan swap for more air inside the car. Courtesy Evo626.
http://www.mx6.com/forums/1g-mx6-gen...cold-here.html (MPV blower installed in my 626=burrrr its cold in here) |
#77 (permalink) |
the only difference i found in the combo switches was the cruise connection. all the other connectors pluged up and worked properly on my 626. the 1ga switch used a 4 wire 4 pin connector and the 1gb switch had a 3 wire 4 pin connector. i switched mine to get variible intermitten wipers cause my dx 626 didnt have it.
91 626 DX, 89 F2T swapped, probinator chipped ecu, 2.5 inch exhaust and downpipe, zebel housing, 10 psi, mazdaspeed FSTB, blaster2 coil, pacesetter sts, rstb and lower tie bar, suby calipers, rear disc brakes, PGT rear swaybar, eibach springs
http://www.cardomain.com/ride/2146610 http://www.dfwmazdas.com |
#78 (permalink) |
Are the injector clips the same between the 90-92 NA's and GT's?
If so, then the Mazda 1.8L I4 (BP motor found in the Escort GT's) injector clips are identical. I know for sure they are identical to the 90-92 NA's, but not sure if the GT's have the same clips (I know the 88-89 NA's and GT's share the same clips) |
89MX6 GT 4WS - Not stock... 135whp/170wtq@7PSI on blown VJ11
#81 (permalink) |
mazdaspeed has a front strut tower bar from a capella if u can find one, like this one
#83 (permalink) |
Back to the Booster
if you switch out the whole thing and do a little of cutting it works. i had 2g seatbelts in my 1g
My Garage
1987 MX-7 Worklog 1988 MX6 GT 14.8 @ 95mph 11psi on stock turbo --- motor going into the RX-7 1988 MX6 GT --- The DD - Stock + HKS SSQV |
#84 (permalink) |
2ng gen rear trailing arms are a direct fit & a nice upgrade, tubular design, much like awr's & cheap as hell!!! all ya gotta do it attatch the ebrake mount a little off, but the difference is sweet for the 10 bux I spent on mine!! pics to prove it..
'90 pgt.....the usual mods
...........ps....I don't ask questions prior to searching Founder of the home for the grammatically challenged .....few pics of my baby!!... http://s212.photobucket.com/albums/c...izzo90_photos/
#85 (permalink) |
Hi, guy I got part numbers for does who might want ARP head bolts, they do not have a kit so you have to order them per bolt.
Ok I called ARP and gave them the messurements for the head bolts holes. Head thinkness 76mm, block bolts depth 29mm and the tread Pitch 12 by 1.50 ARP 2000 Part number# AU4.950-2B $20.22 US per stud Washer part# 200-8516 (per washer) $.94 Nuts part# 300-8307 (per nut) $4.33 If anybody looking for ARP head bolts. |
92 240sx turbo,92 red mx6 gt
You want some? COME GET SOME!!! Ka24de-T (T67turbo) Team Draggone |
