winter and no heat - Mazda MX6 Forums: MX6 Forum
Old 2-10-06, 22:57   #1 (permalink)
winter and no heat
hey guys im in ny and its cold my car isnt pumping out the heat i need to live like a normal american. if i leave my car running for some time with the air off i will get some heat when i turn it on but it dies down. the blowers work at level 1-3 4 doesnt work. it does blow warmer air but not warm enough. the level is topped off everything is good as far as that but what else can cause that.
deevilgnius is offline   Reply With Quote
Old 2-10-06, 23:10   #2 (permalink)
  Total: 163 Power: 5
megalomaniac32x's Avatar
sounds like 2 problems, the t-stat could be bad and maybe a blower switch.
91 626 DX, 89 F2T swapped, probinator chipped ecu, 2.5 inch exhaust and downpipe, zebel housing, 12 psi, mazdaspeed FSTB, blaster2 coil, pacesetter sts, rstb and lower tie bar, suby calipers, rear disc brakes, PGT rear swaybar, eibach springs, MSD 6A, ic hardpipes, DSM recric valve, AWR mounts
Old 2-11-06, 1:22   #3 (permalink)
  Total: 485 Power: 5
retsamaksrepus's Avatar
Blower levels 1-3 run through resistors where as level 4 does not, which means the blower should be fine, but perhaps there is a loose connection somewhere along the line for #4.
If life were easy, everyone would do it.
retsamaksrepus is offline   Reply With Quote
Old 2-11-06, 10:14   #4 (permalink)
  Total: 14 Power: 5
I live in wisconsin and used to own a older 626 with the 2.0 8v efi engine. In winter, when it was really cold outside, the car never seemed to blow that much heat. It was like the poor little car and engine just was not able to overcome the bitter cold temps outside to make that much heat. The result of this was that there was not that much heat blowing out my vents in my car.
What you will see people do here in wisconsin in winter is they will block off part of the radiator with a piece of cardboard or something and this will allow the engine to build more heat and thus you get more heat inside the car too. You just need to keep an eye on your temperature gauge to make sure the engine isn't getting too hot. And also to remove the cardboard or whatever when it becomes warmer outside.
If you try this start by blocking say 1/4 of the radiator and if this doesn't help try 1/2 the radiator. I would think eventually you will find a point where you get better heat in the car and your engine temps stay within normal operating temps. Some people will actually attach something on the outside of the car where your openings are for the radiator. It looks kinda crappy but serves the same purpose.
If you've tried the other things like mentioned in this thread and nothing seems to work then this might just do the trick. Just keep an eye on your temp. gauge. Valvestem.
do we all spin together???
Valvestem is offline   Reply With Quote
Old 2-11-06, 10:19   #5 (permalink)
  Total: 222 Power: 5
sounds like a clogged heater core to me...
1994 Ford Mustang Cobra (#1100 of 5009)
2001 Chevy Blazer ZR2
Tyler's GT coming soon...
AdderMk2 is offline   Reply With Quote
Old 2-11-06, 11:31   #6 (permalink)
  Total: 1512 Power: 5
These cars produce plenty of heat, even in the bitter cold (at least after they're warmed up). When it's blowing cold air, what is the temp gauge in the cluster reading? If you're blowing cold air and the temp gauge is showing normal, most likely a heater core. If the temp gauge never reaches normal or is all over the place, thermostat is probably stuck open.
The not working on selection 4 is most likely the switch in the dash. If it were 1-3 not working, it would be the resistor pack behind the glove box.
Old 2-11-06, 19:54   #7 (permalink)
  Total: 1051 Power: 5
Dyoel182's Avatar
Sounds like the heater core to me. I have the same problem in my car and have been planning on swapping the hoses to try and unclog it.
Old 2-11-06, 20:03   #8 (permalink)
  Total: 330 Power: 5
TR-mx6's Avatar
You got enough coolant in there? Is the thermo stuck open and is the heater core blocked? Are the only 3 questions you should ask yourself right now.
TR-mx6 is offline   Reply With Quote
Old 2-11-06, 20:05   #9 (permalink)
  Total: 12 Power: 5
DragonCustom6's Avatar
I agree here
I have nothing important to say so Ill use a classic. Knowing is half the battle...Go Joe
http://www.mx6.com/forums/showthread...25#post1411125 Leave me some feedback if I bought or sold
DragonCustom6 is offline   Reply With Quote
