problems with my brakes - Mazda MX6 Forums: MX6 Forum
Old 3-9-06, 14:28   #1 (permalink)
  Total: 12 Power: 5
here is the problem. i just got my first gen about a few months ago. i bought it real cheap but it needed the head gasket so i really never drove it b4. i did the heads gasket(still running a lil rough) but i notice that the abs light is on. when
i drive it out my shop i had no brake padel presusre. the brakes were going to the floor. my brakes are good so that is not the problem but would the abs unit cause this problem.......guys need help fast..........i should have keep my second gen
94blck6 is offline   Reply With Quote
Old 3-9-06, 14:36   #2 (permalink)
Experiment 626
  Total: 736 Power: 5
anarchyx34's Avatar
It's unlikely to be an ABS problem, more likely you've got a bad master cyl, a blown brake line or just some air in the system. What's the brake fluid level like?
Anarchyx
'96 BMW 328i sport
Old 3-9-06, 14:37   #3 (permalink)
  Total: 12 Power: 5
the brake level is good....maybe i have to change the master cylinder.....
Old 3-9-06, 17:21   #4 (permalink)
  Total: 12 Power: 5
found the problem with the rough idle....loose injector wire. changing the master cylinder tommorrow
Old 3-9-06, 20:16   #5 (permalink)
  Total: 12 Power: 5
guys still have the problem
change the master cylinder but still have the problem....my brother says it its the abs unit that is messed up...guys please help
