#4 (permalink) |
Start from the beginning. Was the cam gear installed with the head or did you change it over? The pin should be at the 12oclock position? Then the gear place on number 1 so the pin is below the number one. It really does not matter wear the pin is now just make sure it is below number 1. To tighten or loosen there is a hole to the right of gear where you place a flat screw driver through and it will lock the gear while you tighten it. Sounds like it is not in time.
Did you remove the bottom cover to verify the crank was set correctly. I remember someone posting if they had to remove the bottom cover. The cover does has the timing marks but I do not think you would be able to tell if it was off by a tooth. |
#6 (permalink) |
Tighten up your cam gear, redo your belt (sounds like youre off by a tooth or two) and try again. VAF? Who unplugs that to do a head? Jon, have you had any drinks watching football today
-Tyler |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#8 (permalink) |
Boy you give up easily
Did the head come loaded or did you have to transfer all valves, rocker arms, HLAs, etc. over? -Tyler |
#14 (permalink) |
Asshole of the Internet
loose plug wire or massive vacuum or fuel leak
Really?
