Comments On: DIY: Shifter Bushing Replacement PICS GALORE!
Comments on: http://www.mx6.com/forums/1g-faq-gen...cs-galore.html (DIY: Shifter Bushing Replacement PICS GALORE!)
Good write up, nice details. If only I had a 1G. Last edited by Panther37 : 9-15-07 at 6:57. Reason: FAQs / How-To Conversion |
#2 (permalink) |
by the way i am sure there will be input about how people did this differently, or stuff i screwed up. And i welcome those comments, there is more than one way to skin a cat. So let me know. I just figured it might be nice to finally have a thread like this with pictures so you really know what to expect.
TeamRaginKansasioCo-Founder
People's Clockless Republic of goatcrapp VP |
#6 (permalink) |
ur rack is leaking!
http://www.cardomain.com/ride/2146610 http://www.dfwmazdas.com |
#7 (permalink) |
One thing about the front vertical bolt (maybe for the rear one too?) is that I think I remember it being threaded into the bracket of the shifter rod as well. So not only does the nut have to come off, but you have to unscrew the bolt to get it out instead of just pushing it.
It's been two years since I did this, so someone correct me if I'm wrong. Another thing is about the secondary linkage bushing... to be safe, the stud should be threaded into the tranny and tightened (two nut method) and then the bushing, linkage, washers and nut. It's a stud for a reason, and using it to tighten the linkage down could strip it out of the aluminum tranny and ruin your day. I had to helicoil all 6 exhaust manifold studs before I learned that lesson... Great write up though! -Todd |
'88 626 touring sedan - SOLD
'92 MX6 GT parts car - SOLD '95 Nissan Maxima - JUNKED '93 MX6 LS |
#10 (permalink) | |
And thats why there are so many broken MX6's. Thats another in the list of things I've done for other people- changed shifter bushings on two cars.
#11 (permalink) |
Yea, because if every MX6 owner read your posts, there would have nevAr been a 1G in a JY, evAr!
Your 4wheeler Greg? -Tyler Last edited by tyler886 : 9-12-07 at 14:04. |
- "An Intense Commitment of Your Total Satisfaction" - Mazda - The Overhaul
1989 MX-6 GT All-Original 59k 1994 Eddie Bauer Bronco - 351W w/ E4OD Need Brake Pads for a car or truck? |
#13 (permalink) |
Man, to tell you the truth I can't remember to save my life If i ever changed those front bushings out. one more thing i gotta look at now, thanks for the reminder!
90' GT - All Original LE Swapped Leather Interior Mod
...b00sting in luxury... Quote:
#15 (permalink) |
Good write up
05 STI
