Old 10-29-07, 23:12   #1 (permalink)
  Total: 32 Power: 2
Where 2 install the oil pressure sender on n/a f2?
I have recently got an oil pressure gauge and I need 2 put the sensor on the end of a pressurised oil line. this would b all good if i had a turbo f2 but mine is n/a. What is the best thing 2 do 2 install the sensor? would I have 2 relocate the oil filter or are there still the holes on the block for the turbo models i could just use???
tx5_brent is offline   Reply With Quote
Old 10-29-07, 23:17   #2 (permalink)
  Total: 32 Power: 2
How the hell did my thred end up in forced induction???
o well if some1 wants 2 help me even though i cant even post a thread right il b more than happy lol
Old 10-30-07, 8:53   #3 (permalink)
  Total: 259 Power: 4
lundgren420's Avatar
get yourself an oil sandwich plate and put it behind the oil filter then BAM four 1/8npt ports simplest way, trust me. I just did it.
1989 Probe GT M/T -my new toy
Old 10-30-07, 13:03   #4 (permalink)
  Total: 770 Power: 0
Yeah, the sandwhich plate is your best bet. Otherwise I cant think of anypace on the F2 where there IS an oil line
Old 10-30-07, 17:39   #5 (permalink)
  Total: 32 Power: 2
Smile
Thanks, it has also been sugested that i could take out the standard oil pressure switch and put a t-peice there so i can still run both sensors. I will check it all out 2day hopefuly. Thanks 4 your help.
Old 10-30-07, 18:09   #6 (permalink)
  Total: 485 Power: 5
yeh, just take out the stock poil pressure switch and run the both switch
1992pgt.. http://www.cardomain.com/id/ademan
1991pgt..http://img525.imageshack.us/my.php?i...wcar002jn7.jpg
Old 10-30-07, 21:34   #7 (permalink)
  Total: 259 Power: 4
Remember thought that the oil pressure sending unit is m10x1 where as all the t fittings you will find are going to be 1/8npt. Try threading that and you will either leak oil or strip a set of threads off into your block. I personally was leaking oil and couldn't take it any more and bought the sandwich plate. Good Luck , If however you find the correct union t to pair the metric and npt fittings post it for future use. Thanks.
Old 10-30-07, 21:37   #8 (permalink)
  Total: 32 Power: 2
Yer im going 2 run with the t-peice idea. No one i asked had even heard of using a sandwitch plate lol so the guy at repco found all of the thread sizes and has ordered the correct adaptor for me.
I might do a "how 2" on installing a oil pressure gauge considering it seems to be so confusing.
Old 10-30-07, 22:04   #9 (permalink)
  Total: 259 Power: 4
Check them out
eBay Motors: OIL FILTER SANDWICH ADAPTER MAZDA MX-3 MX-6 PROTEGE 626 (item 250182182303 end time Nov-06-07 16:35:04 PST)
Old 10-30-07, 22:24   #10 (permalink)
  Total: 23 Power: 2
looks like that could be used to run an external oil cooler if someone wanted to!!! i may just do that!!!
89 Mx-6 GT 4ws Black....open cone filter, Jay-B chip, Turbo XS manual boost controller, autometer guages (boost, oil pressure, and narrow band), millenia 11lbs. wheels (painted gun metal), Passport 9500i
Derek is offline   Reply With Quote
Old 10-31-07, 2:00   #11 (permalink)
  Total: 770 Power: 0
Incorrect. You just need to know where to look to find them. Aeroquip makes all sorts of various fittings, and JEgs/Summit carry dozens of other brand also.
Old 10-31-07, 19:42   #12 (permalink)
  Total: 32 Power: 2
Well i did the t-peice. i gotta go and tighten 1 thing but apart from that it works well. it was F*&#ing hard 2 fit though. I spent about 20 minutes trying to make my 23mm socket fit because the 24 had no chance before i realised maybe its af??? so for referance the oil pressure switch is 15/16. i thought i was going nuts .
Im probly going to end up getting a sandwitch plate (i wanted 1 in the 1st place but couldnt find 1 thanks anyway lundgren) when i fit my turbo... u guys in the us have it good coz down here in aus there arent that many parts available 4 our cars.
Thanks 4 ur help
