What should I do about Fuel? - Mazda MX6 Forums: MX6 Forum
Old 11-27-07, 8:16   #1 (permalink)
  Total: 28 Power: 5
Hey guys I am getting a 16G turbo my F2t and I am trying to reach 300HP. I am looking at a fuel setup but Im not real sure what I need to go with. Should I go with a 190 or 250 fuel pump? What Fuel Pressure Regulator? What size injectors? Is there anything else I would need? Thanks
Ronnie01 is offline   Reply With Quote
Old 11-27-07, 11:52   #2 (permalink)
  Total: 1118 Power: 5
zlyricist's Avatar
you need atleast 460cc's to make 300hp. i made 298whp on rx7 460s
you can use a fpr, and fmu setup to control fuel. at 300hp you will need to control timing, or use race gas. 190 walbro will work just fine
1991 gt - still busted
1999 626 kl manual
2002 maxima
Old 11-27-07, 12:49   #3 (permalink)
  Total: 0 Power: 0
You sure 300whp is acheivable with a 16g?
Old 11-27-07, 12:59   #4 (permalink)
  Total: 216 Power: 5
DarkMx-6's Avatar
sorry guys for my ignorance but isn't a fpr (fuel pressure regulator) and (fmu Fuel management unit) the same thing? Whats the difference? They both sit on the return fuel line to up the fuel pressure right?
Old 11-27-07, 13:10   #5 (permalink)
  Total: 0 Power: 0
Nope. Different items. An FMU increases fuel pressure per the amount of boost you run. An AFPR just increases/decreases base fuel pressure.
So you need an AFPR to adjust the base pressure for the bigger injectors, then the FMU to control the extra fuel under boost.
Old 11-27-07, 13:54   #6 (permalink)
  Total: 216 Power: 5
DarkMx-6's Avatar
so then does it matter which one comes first on the return line? i would imagine it would be fuel pump - engine - fmu - fpr
Old 11-27-07, 15:18   #7 (permalink)
zlyricist's Avatar
i think funhouse got about 280whp w his. thats probably the max though
1999 626 kl manual
2002 maxima
Old 11-27-07, 17:41   #8 (permalink)
  Total: 634 Power: 5
more than hundred people already dyno over 340-360whp on evo3 16g, even big 16g will suppot 300whp
1990 mx6lx compilation
13.5@102.9 on 87shot
Old 11-28-07, 1:06   #9 (permalink)
  Total: 0 Power: 0
moe that hunded people aleady dyno over 340-360whp on evo3 16g
Yeah, on DOHC 16v DSM motors. Not SOHC 12v stump-pullers. Theres a huge difference between a F2t and a 4g63.
Also, IIRc there's 2 models of the 16g (Big 16 and regular). I suppose the power outputs differ between the 2.
Old 11-28-07, 7:39   #10 (permalink)
  Total: 28 Power: 5
Its a big 16g and it'll have no problem gettin 300hp, there are a ton of dsm guys hittin well over 300hp on one so doing it on a f2t should be no problem either.
Old 11-28-07, 11:58   #11 (permalink)
zlyricist's Avatar
yes, but a dsm is dohc and the head flows much more than a f2t
1999 626 kl manual
2002 maxima
Old 11-28-07, 12:05   #12 (permalink)
  Total: 0 Power: 0
Yet Nick barely got over 300whp with a massive t04e. And Z barely got 300whp with a fairly large turbo also.
Old 11-28-07, 16:41   #13 (permalink)
SD6
  Total: 733 Power: 5
SD6's Avatar
Solution: Buy a dsm, heh.
1989 GT - Red
1989 GT - Black
2011 CX7 - Black
SD6 is offline   Reply With Quote
Old 11-28-07, 18:20   #14 (permalink)
zlyricist's Avatar
solution: buy a fe3
1999 626 kl manual
2002 maxima
Old 11-28-07, 18:38   #15 (permalink)
  Total: 28 Power: 5
Im thinkin now some 550cc injectors or bigger. 460s would prolly be running pretty high IDC with what im wanting hp wise.
