Old 5-3-08, 22:26   #1 (permalink)
  Total: 665 Power: 2
defiler's Avatar
Wideband owners... afr question?
So I'm just curious as to what everyone else's reading are, tos ee if mine are normal...
At idle, if the car is cold, it reads 18:1.... if it's warm, it's around 16.5-17.1...
Is it supposed to be that lean at idle? I'm familiar as to what its supposed to be under cruise and boost, but never really looked into what its supposed to be at idle...
I know the gauge is right, because my other readings are normal:
On cruise on the freeway, I'm an even 14.8-14.9...
and under boost, its a nice 11.5-1, and dips to 10:1 at 9PSI...
89MX6 GT 4WS - Not stock... 135whp/170wtq@7PSI on blown VJ11
Old 5-4-08, 0:00   #2 (permalink)
MX6.com Supporter - Click Here for Information 4ws whore.
  Total: 253 Power: 1
compnut21's Avatar
just a tad rich and lean. i do 16.5 under idle/cruise, 11.5 everywhere else. warmup is like 15 idle. also i have ms so i guess my cars readings dont mean [shizzle].
89 GT 4WS/Megasquirt/Zebel o2/2.5" Exhaust/10ish psi
1989 Wiring Diagram PDF
Useless crap for sale
compnut21 is online now   Reply With Quote
Old 5-4-08, 11:12   #3 (permalink)
  Total: 665 Power: 2
defiler's Avatar
You cheat. you can control what yours are at
Old 5-4-08, 21:34   #4 (permalink)
f33n's baby maker
  Total: 1598 Power: 5
Zach's Avatar
someone get me a wideband, and I'll let you know :P I've got a zombiess chip, supposedly those lean out the fuel table a bit...
Build My City and Instrusty Up! <<<<Click It!
My 57 trim build progress
My Retrofit Thread!
I think goatcrapp is the frickin _ _ _ _ _ _ _!
Zach is online now   Reply With Quote
Old 5-4-08, 21:39   #5 (permalink)
  Total: 665 Power: 2
defiler's Avatar
Well now that I have my trusty wideband installed, I'm going to test out both the Zombie and AdamTurbo chips and see what the real difference is...
Old 5-6-08, 22:36   #6 (permalink)
  Total: 51 Power: 2
your a/f at idle seems high mine stays around 14.6-15.4 idle/cruise then under boost it dumps in fuel lol.
i want ms :P so i can get your idle readings and save gas lol
Originally Posted by SixSick6 View Post
I pass on Craigslist myself. I put an add for a running partner on weekends and got a reply from a guy saying he isn't interested in running but would gladly lick my balls afterwards.
1990 Ford Probe GT http://www.cardomain.com/ride/2298880/1
PGTF2T is offline   Reply With Quote
Old 5-7-08, 11:07   #7 (permalink)
  Total: 665 Power: 2
defiler's Avatar
Thats why I try and stay out of boost
Maybe I need new plugs. I pulled one and they look pretty white. Plug wires are a little old also...
Old 5-7-08, 11:18   #8 (permalink)
f33n's baby maker
Zach's Avatar
defiler, those readings are fine...if you were richer at idle/cruise you would be wasting gas...that's not a good thing.
My Retrofit Thread!
Old 5-7-08, 11:26   #9 (permalink)
  Total: 1121 Power: 5
fredio54's Avatar
3 1G members with wideband! wow, that's more than I thought :-p
(yes, I know you have one too carnage)
Old 5-7-08, 11:44   #10 (permalink)
  Total: 887 Power: 5
zlyricist's Avatar
you shouldnt notice a difference with idle and cruise between the two chips if all your sensors and ecu calc's are doing there job. the only difference you will see is at WOT
your idle a/f ratios are way lean, mine was always consistent with my cruise ratios
91 GT hy35 build in the works
06 maxima - the daily
Old 5-7-08, 11:46   #11 (permalink)
  Total: 665 Power: 2
defiler's Avatar
Weird. Im at 15.2 when I hit cruise at 55mph, but at 65mph its at 14.8... at 85 its way down to 12.4 on cruise...
Old 5-7-08, 11:54   #12 (permalink)
  Total: 222 Power: 3
lundgren420's Avatar
me too, me too. I just wanted to chime in : )
1989 Probe GT M/T -my new toy
Old 5-7-08, 14:05   #13 (permalink)
fredio54's Avatar
Could lean at idle = small air leak? or would the o2 correction fix that??
Duh! LOL, cruising at 85mph uses quite a bit of power = quite a bit of load = needs 12.5AFR :-)
What kpa are you at at 85mph?? ie, how far in boost or vacuum?
Whats the bet its like 2psi or 0psi or something similar? Pretty good i'd say.
Fred.
Old 5-7-08, 14:13   #14 (permalink)
  Total: 222 Power: 3
I guess it only counts if it is hooked up and in use.
Old 5-7-08, 16:11   #15 (permalink)
  Total: 46 Power: 3
My wideband is always running in my car. idle lately is much leaner than it used to be 15-16 area now (14 bang on before)... crusing anywhere from 13.5-15 and wot goes to 9.5 and creeps back up to 11 and stays there.
I leaned out and melted a piston last fall so now i run the wideband all the time. Its shown me when to get off the throttle a few times now. Well worth the $350 id say.
pick_arse is offline   Reply With Quote
