Old 5-22-08, 1:15   #1 (permalink)
  Total: 0 Power: 0
Question quick question about different year engine swap?
I own a 1990 mx6 gt turbo with a 5 speed. The other day i blew my lower end of the motor and just purchased a 89 motor for it to replace the blown one. Now the question is what all is involved in the swap to make it compatible to my comp and wiring? I was told my intake is one piece but was wondering if I take it off right from the block or what? Was also told distributor and thermostat housing. Any other advice on this swap is much needed and appreciated. Thanks 2 all who help and have been a help up to this point!
mx6 z28 is offline   Reply With Quote
Old 5-22-08, 1:19   #2 (permalink)
  Total: 0 Power: 0
Also I will be running boost control with a 2.5 straight back exhaust and cold air intake, and was wondering which chip is good to use, and whether I should upgrade my injectors or not, and what else might be good to upgrade?
Old 5-22-08, 10:34   #3 (permalink)
  Total: 46 Power: 4
i think one of the water temp sensors is different but its quick swap
zombie or probinators chips are probably your best bet
leave the injectors alone unless your going to a big turbo
pick_arse is offline   Reply With Quote
Old 5-22-08, 10:46   #4 (permalink)
MX6.com Supporter - Click Here for Information im back from BAN camp
  Total: 345 Power: 4
maffatato15's Avatar
The 88-89 have 6 wire distributors and the 90-92 have 4 wire distributors. If you put the whole 89 engine in you will have to change distributors. As for the temp sensor i think you could just unscrew the one you dont need and screw the other one you need right in its place. Thats all i can really think of right now....
1991 lxt - parting out...ask for parts
1989 mx6 GT -LE Leather seat swap!
Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar, soon to be installed tbird
Old 5-22-08, 11:03   #5 (permalink)
  Total: 0 Power: 0
Thankyou guys every bit helps. Now where in the world can i find myself some poly motor mounts?
Old 5-22-08, 11:23   #6 (permalink)
  Total: 22 Power: 0
awrracing.com
04ProbeGT is offline   Reply With Quote
Old 5-22-08, 16:59   #7 (permalink)
  Total: 0 Power: 0
just ordered those engine mounts should get em in to ontario early next week for 200 buckas. Thanks for the link man helps out allot!
Old 5-23-08, 12:17   #8 (permalink)
  Total: 22 Power: 0
i have had mine for a while now and love them
Old 5-23-08, 14:52   #9 (permalink)
  Total: 1509 Power: 5
Strip all of the electricals, sensors, distributor, coolant routing, etc off of the old 90 GT motor and transfer them over to the 89. Only use the bare head/block mechanicals from the 89 GT motor.
