Old 7-17-08, 20:26   #1 (permalink)
MX6.com Supporter - Click Here for Information Non-Turbo 626
  Total: 142 Power: 4
megalomaniac32x's Avatar
MSD install
i got myself a MSD SCI box and a tach adapter. i already had a blaster 2 coil. it is fairly simple and went right in. its not as clean as gavins but it works. so far it started better and idled better. we will see if it feels better tonite on my way to our local meet. here are some pics or it installed on the 626.
http://www.dfwmazdas.com
Old 7-21-08, 13:20   #2 (permalink)
  Total: 165 Power: 4
DarkMx-6's Avatar
Nice man, I'll have to take a look at that later.
For Sale-- 91 White mx6 GT: Boosted N/A block, Fidanza, 9 psi, open Zebel down pipe soon to be full 2.5" , ss braided brakelines, suby calipers, F/R D/S Disks, tokico blues
04 Civic: The daily, CAI,Sloted F Disks, No muffler(sounds way better than ricers) Great on gas
DarkMx-6 is online now   Reply With Quote
Old 7-21-08, 19:37   #3 (permalink)
  Total: 142 Power: 4
well the sad thing was it stopped working later on that nite!! stupid honda guy, i will never buy parts from them again!!! anywho, i found a MSD 6A and installed it and it does run great!
Old 7-21-08, 23:00   #4 (permalink)
  Total: 153 Power: 2
Keeloh's Avatar
How hard is to install a MSD 6A?
89' Lx to 89' GT Swap/Stock Turbo/Probinator Chip 15psi/8.5mm Magnecor Wires/Msd Blaster 2/P&P Head/Exedy Clutch/AWR Trailing Arm/GT Rear Disc Conv/Pacesetter Short Shifter/Upper Bar from Bulldog Racing,Rstb and Lower Tie Bar/ 2 MazdaSpeed Bucket Seats.
Old 7-21-08, 23:03   #5 (permalink)
MX6.com Supporter - Click Here for Information im back from BAN camp
  Total: 345 Power: 4
maffatato15's Avatar
is there really any noticeable difference too?
1991 lxt - parting out...ask for parts
1989 mx6 GT -LE Leather seat swap!
Zombie chip, 2.5 inch turbo back exhaust, aluminum hard pipes, 8.8 mm Accel 300+ ferro-spiral race wires, blaster 2 coil, intrax lowering springs, factory rear strut bar, soon to be installed tbird
Old 7-21-08, 23:27   #6 (permalink)
  Total: 153 Power: 2
Keeloh's Avatar
Easier starting, reduced plug fouling and complete combustion. So yes.
Old 7-22-08, 7:39   #7 (permalink)
  Total: 142 Power: 4
it was easy. it took an hour to install and tidy up. so far its been good
Old 7-22-08, 12:17   #8 (permalink)
All aboard the B& V&
  Total: 1693 Power: 5
Zach's Avatar
What plugs/gap are you using right now?
Also, for this install, use the parts listed in Gavin's write up?
Old 7-22-08, 19:14   #9 (permalink)
  Total: 142 Power: 4
stock NGK and mazda NGK wires. i already had a blaster 2 coil and my setup is just like gavins.
