get some ez outs at craftsman. They are basically a reverse threaded drill bit. Drill into the bolt with one regular bit to make a hole, get a small hammer and tap the other reverse bit into the hole. Get your drill and pull that [fizzle]er out.
Either that or use a rachet and as your spinning it get a flat head screwdriver on the inside of it to force it out while you spin it at the same time. If its cross threaded and spins its easy to get out. If its stuck its more of a bitch but still pretty easy for the most part.
Also that thingy is the intermediary shaft, and the part with the bolts is your intermediary shaft hub and bearing assy.
Anyway after you get the bolts out make sure you try to spin it before you pull out the axles or try to pull it out. Believe it or not it will spin. I didn't think so and was stuck here for a whie trying to figure it out till i took someone's advice on here and decided to swallow my pride and tap it. And like i said, the dumb thing flipped over and well made me look stupid in the process
