a/c need help asap - Mazda MX6 Forums: MX6 Forum
Old 5-26-09, 18:51   #1 (permalink)
a/c need help asap
i'm in need of some help. here's the problem when i pull vacuum on the a/c unit and the vacuum is complete and close off the vacuum and take off the red hose (high side) it start sucking air back in the line. is the stem in the hose bad or am i doing something wrong. i need to get the a/c runnig before it get to hot. thanks in advance
UP GRADE is offline   Reply With Quote
Old 5-27-09, 15:48   #2 (permalink)
  Total: 1951 Power: 6
Zach's Avatar
sounds like something could have crack in it.
I still have those parts you wanted...good condition as well. It held the freon great.
88 626 4WS Turbo Noble White
97 626 LX V6 Timberline Mica
Email me for a turbo rebuild!
Old 5-27-09, 16:10   #3 (permalink)
  Total: 417 Power: 5
The tire valve tool and new valve should be under 5 bucks. Has it been converted to r134? Buy a new one and put it on. Pull another vacuum and leave it connected for several hours. Then check the pressure to make sure you do not have anyother leaks. If you have had a leak there when the a/c was charged then you most likely are out of oil as well as freon. If that is the case your compressor maybe toast. When the compressor goes it will send metal pieces to the dryer and clog it up. Also the expansion valve is clogged up. You could try to charge it and add oil and see what you get but if get warm or cool air instead of cold then you are looking to replace all 3 items.
allmazda is offline   Reply With Quote
