Old 11-12-09, 18:38   #1 (permalink)
  Total: 13 Power: 2
broken bolts....
alright i took my turbo off because the seals are blown on it, and there is oil all over in the exhaust housing of the turbo, it was bad...haha but i have a broken bolt on the manifold, and the manifold bolts that bolt it to the head, and i wasnt sure on what the best way to get them out was, so i was just wondering if i could try anything to get these out so i dont have any leaks, ill get some pictures of the turbo up soon tho
1990 Mazda MX6 Turbo, Automatic, no rust...finally...white with blue interior
1988 Mazda 626 Turbo 5 door, blew up, sitting in driveway don't know what to do with it yet
1990 Mazda 626, N/A, Automatic, Parts Car
randys626turbo is offline   Reply With Quote
Old 11-12-09, 19:24   #2 (permalink)
  Total: 10 Power: 0
Umm if its easy to get to you can prolly drill it out if not. Id say take it off take an acetylene torch and get the manifold hot so it expands and maybe weld a piece on to the bolt to finagle it out.. might work O_O i dunno going out on a limb hope it helps >_<
DiaMagus is offline   Reply With Quote
Old 11-12-09, 20:39   #3 (permalink)
  Total: 13 Power: 2
thats not a bad idea at all i for the manifold to the head bolts would be hard because i dont have a welder here so i might have to take it somewhere and have them do it for me
Old 11-12-09, 20:40   #4 (permalink)
  Total: 10 Power: 0
Id remove the manifold, especially if you drill. wouldnt want shrapnel getting in to the guides/seats
Old 11-12-09, 21:44   #5 (permalink)
  Total: 13 Power: 2
u think i should just drill it out one size bigger at a time then just tap it out or what
Old 11-13-09, 8:26   #6 (permalink)
  Total: 59 Power: 2
You mean you broke one of the exhaust manifold studs?
1992 Celica GT F-Prepared
1993 Escort GT ST
1990 MX6 GT Turbo The DD. Supra CT-26 50trim, 440cc injectors, Aeromotive AFPR, Walbro 255lph, Greddy Profec B, Greddy Type S, Tial 38mm, fmic, 2.5" ic piping, 3" side exit exhaust, probinator chip, Innovate LC-1, 2g GR2s/Megan Springs. (LOW)
Old 11-13-09, 9:58   #7 (permalink)
  Total: 950 Power: 5
No. Get a broken bolt extractor and use the right size drill bit, drill into the broken stud and extract it. they rarely get stuck in the head and usually come out easily.
If your going to drill a bigger hole then use heli-coils, the threads left by your average tap set aren't going to hold the studs.
You can also try a rotary tool (like a dremel) and a small cut off wheel, just cut a grove in the stud and use a flat head screw driver and unscrew it, if this fails use the groove to center your drill bit and try the bolt extractor.
Old 11-13-09, 10:35   #8 (permalink)
  Total: 13 Power: 2
im just going to take it in to a friends shop to mess with the head bolts but i need a new manifold i think because i cannot get the old bolt out of the manifold i broke one that connects to the turbo too...it must have just been soft or something because it just came right off
Old 11-13-09, 14:13   #9 (permalink)
  Total: 63 Power: 5
Good idea. Make sure you spray Liquid Wrench, WD-40 or similar before doing this. I know from previous experience that some shops will charge many hundreds of dollars to do this.
89 MX6GT
01 Corvette Z51 Coupe
06 Lexus RX400h
Old 11-14-09, 16:08   #10 (permalink)
  Total: 487 Power: 5
chief tool's Avatar
As far as the head goes, you must be talking about a very average tap set.....I re drilled mine and tapped them to 10x1.25 and fitted some FE3 studs...there was no issue. Mind you I did mine pre emptively before any of them broke
I drilled the holes slighly smaller than you otherwise would in steel just to make sure it would be ok....I tested it out on an old junk head that I had and it was fine before I did mine one the car.
I loctited the studs in to make sure.
As for removing broken studs in the exhaust manifold where the turbo attaches....I had to remove 3, and I tried every trick in the book to get them out, and n the end had to drill them out....
Problem is that those studs are very hard, and will blunt most drills, and its hard to get a thread extractor to bite into the metal.
By the time you drill a large enough hole to get a decent sized thread extractor in it...you might as well keep going.
Just get another manifold from the junkyards with no broken studs....it'll be heaps easier!
