Old 11-16-09, 16:45   #1 (permalink)
  Total: 10 Power: 0
Aftermarket passanger side motor mount ~ doesnt line up
Just curious as to why every aftermarket motor mount I find has the bolt holes 1/2" off to the side? was this an improvement, or is this going to jack my motor up if I install it then try to drive it? Just curious if I need to check out pick n pull for a used one or not... Any info would help.
Jsav209 is offline   Reply With Quote
Old 11-16-09, 17:23   #2 (permalink)
  Total: 10 Power: 0
For Turbo,and N/A mount are diferent,maybe you have tried the wrong 1`s.
sva86 is offline   Reply With Quote
Old 11-16-09, 17:54   #3 (permalink)
nmn
  Total: 134 Power: 4
Yeah most likely you've got a N/A mount but good luck finding the GT/Turbo mount.
What I did was just pressed the rubber out of the N/A and pressed it into my old Gt/Turbo mount.
just make sure to keep the orientation the same.
I always take life with a grain of salt, ...plus a slice of lemon, ...and a shot of tequila.
Originally Posted by Ben Franklin
Any society that would give up a little liberty to gain a little security will deserve neither and lose both.
nmn is offline   Reply With Quote
Old 11-16-09, 18:36   #4 (permalink)
  Total: 1082 Power: 5
zlyricist's Avatar
make sure you have the correct mount for the correct transmission
1991 MX6 GT - my slut
95 LS SOLD - 96 M edition SOLD - 93 KLZE new daily
Old 11-17-09, 1:13   #5 (permalink)
  Total: 10 Power: 0
Motor Mount 1989 - 1992 Ford Probe 2.2 Front Right Stan:eBay Motors (item 280412508183 end time Nov-18-09 18:03:27 PST)
So the above link is to an ebay auction which show the exact part, the auction states that it is for the turbo models pgt & mx6. thie is the same mount that Kragan & autozone tried to sell me, if you look at the picture you'll see that the 2 holes are not centered on the mount, they are off by 1/2". can someone please take a look at their cars to see if theirs are off center or centered its the top passenger side mount that sits right near the belts.
Thanks
Old 11-17-09, 2:37   #6 (permalink)
  Total: 41 Power: 3
everywhere i tried to get that mount from had that same one and thats for the N/A engine. the only place out of az, discount and napa hat had the right one was the dealership, lol.
your better off just keeping the old mount and poly filling it for $15 instead of the $200+ at the dealership for the right one.
1991 Mazda MX6 GT - 5-speed, 17" eagle alloy rims with BFG G-force tires, Probinator chip and MBC
pyrotech5 is offline   Reply With Quote
Old 11-17-09, 14:01   #7 (permalink)
  Total: 10 Power: 0
Yeah the dealership here has nothing, what do you mean by poly filling it? is it pretty easy to do?
Old 11-17-09, 14:06   #8 (permalink)
  Total: 10 Power: 0
Also the guy at Auto zone told me that it is a hydraulic motor mount, which kinda makes sense because when I busted it all the fluid came gushing out, would poly filling it still be an option being that its a hydraulic mount?
Old 11-17-09, 22:21   #9 (permalink)
  Total: 380 Power: 5
like others have said. there are two different styles. and there about 1/2 inch difference. its the n/a mount compared to the turbo mount. you dont want to use the wrong mount cause your motor will be sitting at an angle.
~ChiPoC~
Old 11-17-09, 22:47   #10 (permalink)
  Total: 41 Power: 3
basically take the mount out and scrub it clean and let it dry off completely, put the metal spacer back in(the metal tube in the middle of the rubber) if it is to the point of falling out like mine was. center it, and pump it full of polyurethane. i used the 3M window weld for putting in windshields and it has been holding up for over a year now.
Old 11-20-09, 12:58   #11 (permalink)
  Total: 10 Power: 0
I got lucky there wasnt any GT's here in the modesto Pick n Pull, but I found 2 in the Stockton one but one was busted otherwise I would have pulled the extra & posted it 4sale, anyways I am back on the road!!!!!
Thanks for all the help guys!
Old 11-20-09, 13:51   #12 (permalink)
Shove it!
  Total: 1903 Power: 5
Zach's Avatar
this...
mounts are different for auto vs manuals. I've tested this theory in the junkyard once. Auto front and side mounts do not line up to manuals. NA Manual and GT Manual mounts line up.
maybe the change is years for the passenger mount?
I see you trollin I be ragin
Parting out Gray 89 GT
Originally Posted by Kansas
Old 11-24-09, 20:38   #13 (permalink)
  Total: 80 Power: 5
this...
Huh? Define front and side mount...
The pass side mount, I have never checked for auto, but is different from N/A to turbo, the front mount, closest to the radiator is the same between all models, the mount closest to the rack is based on tranny, turbo and N/A are very close, but they mount to the trans different, and the top trans mount is based on trans...
If you use the N/A mount on the pass side, you end up with a very good one wheel wonder and a fighter down the quarter, likes to go to the right...learned that one in high school
Old 11-24-09, 20:42   #14 (permalink)
Shove it!
Zach's Avatar
the mount in the front is very much different between auto/manual but same between GT/LX.
Same with the passenger engine mount. The driver side and rear mount I haven't checked.
