room fuse blows - Mazda MX-6 Forum
post #1 of 4 (permalink) Old 5-30-10, 4:42 Thread Starter
room fuse blows
hey all
give yous a run down what i have been doing
1993 626 gv wagon with 88 626 turbo gd wireing loom the full kit
so a few weeks back before i put the turbo engine in i was having trouble getting the blower motor fan to work but i got that working
so i hooked the rest of the loom up and put the ecu in and when i go to turn the ignition on the room fuse keeps blowing so i pulled pretty much everything back apart and couldent find no fault
but i do rember swapping the 2 relays next to the batter over trying to get the blower motor to work and i used the 2 relays from the gv wireing loom
anyways i completely forgot about the relays and i went to hook the battery up and thats when the room fuse kept blowing
does anyone have any info on these 2 relays next to the battery
this only started when i put the engine in and put the rest of the interior bits back togeather like glove box and steering shroud and center console
other then that the engine cranks fine i can hear the fuel pump head lights and turn signals work fine brake lights work fine
but what doesent work
cd player
ciggy lighter
interior lights
door lights
so to try and find the fault i disconnected the followings
engine loom to dash loom
alternator,starter motor to battery
disconnected the cd player
disconnected the interior lights
still keeps blowings
1988 mazda 626 turbo,5 spd with,2.75inch mandrel bend exhaust system, t25 turbo with stainless custom manifold 2.5inch stainless dump pipe high flow cat,boost gauge,16inch rod rims,rear strut brace,king spring superlows,monza oil catch can,turbo tech boost controller TRE performance 255LPH fuel pump
tx5_cool_dude83 is offline
post #2 of 4 (permalink) Old 5-30-10, 9:34
Quoted: 2 Post(s)
Just for shits and giggles disconnect the blower motor and try it again.
I'm betting it has something to do with mismatched relays.
There are a few circuits (radiator fan for example) that changed form N/O to N/C or vice versa.
And then there are all the different trim levels that the cars could be optioned with (climate control for example)
What you need to do is go through every load, relay, resistor pack, etc, that is connected to the fuse that is blowing until you find the one that that is drawing the current. Then test the item against what the WSM says it should be.
This whole debacle could have been avoided by using the tried and tested methods used by Sabbai and Jessiotrot when swapping their wagons to turbo.
mx_masta is offline
post #3 of 4 (permalink) Old 5-30-10, 14:23 Thread Starter
im betting that its the relays too
because i don't even have to have the accessory or the ignition on for it to blow
post #4 of 4 (permalink) Old 6-2-10, 23:54
If a fuse keeps blowing, it usually means something is amiss in the circuit. The wiring should be checked along with the components in the circuit to determine if there's a short or other problem.
wassssup is offline
